15.9lb 18x7.5 +50mm will it fit and what tire size?
MiniStiGuy
Posted
I was thinking of the same wheel & tire combo myself. I also have '06 ABP LGT.
I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3.:p
Posted
what about a 235/40. wider and softer with possibly curb protection.
If you look at the tire specs, they seem to recommend a rim width of 8" - 9.5" for a 235/40-18...
Seek first to understand, then to be understood.
In other words: SEARCH before you post!
Guest Gitster
Posted
You should get Rota's, $100 less a wheel, plus a few lbs each.
Posted
Go with 225's the 235's will have sloppy sidewalls:(:(
Go lightweight:):):)
definitely go with 225
♪Emancipate yourselves from mental slavery;
None but ourselves can free our minds.♫ -Bob Marley, Redemption Song
Posted
I'd go with as wide of a tire as you can fit on the wheel, so my vote is for the 235s this will give you a wider footprint getting more meat on the ground for better handling.
The ABP wagon has 225/45-17s on 17x7s on it. I really like the wheels...though I'm kinda running out of creative reasons why it has two valve stems (I know the real reason).
Martin Luther - "Who loves not women, wine and song remains a fool his whole life long."
EL4NFZT7
Posted
Redundant valves stems FTW. That way if one of them fails, the other one can still hold pressure.
Posted
More of a contact patch yes but those sidewalls are going to be VERY sloppy:(:(:(
Toyota 6EATS .........SUCK!!!!!!
Posted
Actually, doing some more thinking about this and with the help of the Tire size calculator. I'd go for some 235/35-18's. They are nearly the same size as the diameter of the stock tire, get more meat on the ground and have less sidewall than the 225/40's. Though come to think about it...this might rub, is more likely to hydroplane, is a rare tire size, is heavier, and yeah...wider sounds cooler...but just go with the 225's in this case...
EL4NFZT7
