maomao Posted February 20, 2007 Posted February 20, 2007 Hi, I am in HK and am considering whether to buy LGT wagon or sedan. I can only manage to test drive the sedan, which has good performance and handling, since LGT wagon is not available for test-drive. However, due to the look and practicality, I need to go for wagon. But I have concerns over the interior noise level and also the handling of wagon. I fear that wagon is not as rigid as sedan on cornering. See if you guys can give me some insight. Thanks
Magic Posted February 21, 2007 Posted February 21, 2007 Interior noise level is no more than a sedan (stock) but if you add an aftermarkest exhaust, it will be a little louder inside, but that can easily be remedied with some sound deadening material. As as handling, add some good tires and sway bars along with a rear upper strut tower bar, and your all set. Click my link to check out my wagon, and if you need anything else just let me know (PM me) Click Here everyday:redface:
maomao Posted February 22, 2007 Author Posted February 22, 2007 Hi Magic, Thanks for your reply. Your LGT Wagon is awesome. I see you change the exhaust. As you suggest, did you add some sound deadening material and where? Also, did you add rear upper strut tower bar?
