king_j Posted November 6, 2010 Share Posted November 6, 2010 i think i need horzontal adjustment. do i tighten or loosen the bolt to move the light beam outward? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 8, 2010 Author Share Posted November 8, 2010 I don't remember exactly as it has been awhile since I've worked on some headlights. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
f1anatic Posted December 4, 2010 Share Posted December 4, 2010 How do you align the hi beams. I have Toshiba HIR bulbs and they are next to useless since they light up the sky not the road. They project much much further; I would like them to in fact overlap with my low beams. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 4, 2010 Author Share Posted December 4, 2010 you can't really as they are not self adjustable. The whole highbeam/lowbeam unit is one big unit and adjust all the same for both lights at the same time. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ppettit2005 Posted December 15, 2010 Share Posted December 15, 2010 I can't get any motion out of my head lamps. I turn the screw one way and nothing happens. If I turn it the other way, nothing happens. I can't see shit at night, so tomorrow morning I am just going to take my car to the dealership and tell them to fix it. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 15, 2010 Author Share Posted December 15, 2010 what are you using to adjust them? screw driver? socket? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ppettit2005 Posted December 16, 2010 Share Posted December 16, 2010 I'm using a socket. I called the dealership and they said it was $45 to re-aim my headlamps. I'm broke, soo for now I am just going to drive around at night without being able to see. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 18, 2010 Author Share Posted December 18, 2010 give it another shot they should move. it isn't anything drastic or anything but they should move after a few turns. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
GTS Jeff Posted December 18, 2010 Share Posted December 18, 2010 Even the pressure of pushing on the adjustment screw should move the lamp up and down. Link to comment Share on other sites More sharing options...
ppettit2005 Posted December 19, 2010 Share Posted December 19, 2010 it does, but they won't stay aligned if I just push on the screws. what I need is just higher mounted headlamps at some point. It's like my car just aims them into the ground all the time. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 19, 2010 Author Share Posted December 19, 2010 If el paso wasn't such a drive I would come over to help OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ppettit2005 Posted December 26, 2010 Share Posted December 26, 2010 ok, I got them aligned. your right, they don't change much. Link to comment Share on other sites More sharing options...
blackturboblack Posted January 9, 2011 Share Posted January 9, 2011 I don't know if I've got this. Horozontal moves the bulb side to side, as in along the horizon? And vertical moves it up and down? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted January 9, 2011 Author Share Posted January 9, 2011 That's correct you've got it right. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
blackturboblack Posted January 11, 2011 Share Posted January 11, 2011 I installed those MSI (I think) springs. I'm dropped about an inch all round. Question: how far should I raise ( adjust) my headlights to compensate? 1/2 turn? 1/4 turn? I know, I know, I should do the wall-measuring thing, but until all this snow melts it's not gonna happen. Just need a quick temporary fix. What would you guesstimate? Both screws? One? TIA. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted January 12, 2011 Author Share Posted January 12, 2011 just because you lowered the car doesn't mean that you need to raise the lights. Unfortunately when you lower a vehicles height you lose distance on visibility. It's one of the things that happens. If you raise a car though you can distance. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
blackturboblack Posted January 13, 2011 Share Posted January 13, 2011 LOL. Damn, Mini, you're killin' me here. I think I need a little more throw. The immediate front road is brightly lit, but the distance (say 3-4 car lengths) is dim. Or maybe I'm out-driving my lights! I tend to do that. BTW, I'm using 65w rallye and 55w yellow fogs, which I can't even see because the heads are shooting down so close. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted January 13, 2011 Author Share Posted January 13, 2011 well the only way to be 100% sure is to do the alignment process. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
blackturboblack Posted January 14, 2011 Share Posted January 14, 2011 **sigh** I know. All this effin' snow... Link to comment Share on other sites More sharing options...
GTS Jeff Posted January 17, 2011 Share Posted January 17, 2011 I installed those MSI (I think) springs. I'm dropped about an inch all round. Question: how far should I raise ( adjust) my headlights to compensate? 1/2 turn? 1/4 turn? I know, I know, I should do the wall-measuring thing, but until all this snow melts it's not gonna happen. Just need a quick temporary fix. What would you guesstimate? Both screws? One? TIA. Find an indoor parkade. Link to comment Share on other sites More sharing options...
Newbie757 Posted March 26, 2011 Share Posted March 26, 2011 Hello I'm new at this, I have recently change my bulbs on my 2010 legacy although I was able to find the vertical adjustment, but my question is there a horizontal alignment on this model? If so where do I find it? Thanks Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 26, 2011 Author Share Posted March 26, 2011 Being that I have never taken a look at 2010 lights I can't tell you exactly where it is. If you can get me some pics of the back of the lights I would be better able to help you out. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
iNVAR Posted March 27, 2011 Share Posted March 27, 2011 Hello I'm new at this, I have recently change my bulbs on my 2010 legacy although I was able to find the vertical adjustment, but my question is there a horizontal alignment on this model? If so where do I find it? ThanksI wouldn't mess with your horizontal adjustment unless you have a good reason to. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted May 2, 2011 Share Posted May 2, 2011 best way to adjust these with the lights in the car? Just got a replacement TYC set fully custom with halos and blacked out housing and driving home tonight I was lighting up interstate signs like a christmas tree, and when driving over bridges the concrete divider, the cut off was clearly angled upwards. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 3, 2011 Author Share Posted May 3, 2011 8mm socket or Phillips screwdriver to adjust the height setting. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
