mpetty Posted February 13, 2007 Share Posted February 13, 2007 Hey gang - I have noticed a whine in the car lately that only kicks in over 40 mph. It has gotten really quite loud, to the point that it overwhelms any other noise at highway speeds. Anyone else notice this? It seems to have appeared since January, when two things happened: 1. It got quite a bit colder in Iowa. 2. I went TDC stage 2. 2005 LGT 5MT It is mostly an annoyance, but it certainly leves me a bit concerned about the status of the trans and diffs. I am going to change the fluids in those before too long to see if it helps, and also to see if they are full of metal shavings... Morgan Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 13, 2007 Share Posted February 13, 2007 Happened to me too, they are replacing the center diff under warranty, I hope! Search a bit, a few others have had the same problem: -speed dependant? -same noise no matter what gear? -clutch in clutch out, no difference? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 13, 2007 Share Posted February 13, 2007 Just had mine fixed. Denial is your best friend Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 13, 2007 Share Posted February 13, 2007 Some details here http://www.legacygt.com/forums/showthread.php?t=54215 Denial is your best friend Link to comment Share on other sites More sharing options...
mpetty Posted February 14, 2007 Author Share Posted February 14, 2007 Happened to me too, they are replacing the center diff under warranty, I hope! Search a bit, a few others have had the same problem: -speed dependant? Yes - gets louder and higher pitched with increased speed -same noise no matter what gear? Not sure - I will definitely check that out. -clutch in clutch out, no difference? No difference. Center Diff, huh. Doesn't sound promising. Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 14, 2007 Share Posted February 14, 2007 Mine was a bearing in the Trans. $1200 to fix. Denial is your best friend Link to comment Share on other sites More sharing options...
mpetty Posted February 16, 2007 Author Share Posted February 16, 2007 Well, I guess it must be diff related, because I confirmed today that it is independent of gear and also is the same with clutch in or out. Fortunately, it is currently just a minor nuisance. I will update the thread when I have the dealer check it out. Link to comment Share on other sites More sharing options...
whitetiger Posted February 16, 2007 Share Posted February 16, 2007 http://www.lucasalexander.dk/images/Arnold-Stop-Whining-sizdow.jpg Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 16, 2007 Share Posted February 16, 2007 Well, I guess it must be diff related, because I confirmed today that it is independent of gear and also is the same with clutch in or out. Fortunately, it is currently just a minor nuisance. I will update the thread when I have the dealer check it out. I will bet you have the same problem as I did. Denial is your best friend Link to comment Share on other sites More sharing options...
Scooter Posted February 18, 2007 Share Posted February 18, 2007 I confirmed today that it is independent of gear and also is the same with clutch in or out. That also describes a bad wheel bearing, which has been a very common failure on the 2005 cars. Search the Warranty/Repairs area for "wheel bearings" or "humming noise". Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
