Scooby2.5 Posted January 10, 2008 Share Posted January 10, 2008 That would be great. My 2005 already had the Subaru Chop Shop done to it when I got it and would prefer to fix it with the newer style. When you take pics show us how much easier it is to change the filter. Link to comment Share on other sites More sharing options...
Bimmer Posted January 10, 2008 Share Posted January 10, 2008 I used to change them every six months, but now I am aiming for every three. I follow Subaru's recommendations... BTW, AFAIK the OEM filter is activated charcoal, so it not only filters out pollen and dust, but actually cleans out nasty air pollutants as well. A German car magazine did a test several years ago on these things, and they actually work... That said, now that I live in the boondocks, maybe I'll switch over to something cheaper. Ben Link to comment Share on other sites More sharing options...
4wheeling Posted March 27, 2008 Share Posted March 27, 2008 I know this is old but did anyone post a picture write up of the 08 retro fit for the cabin filter mentioned above? Link to comment Share on other sites More sharing options...
coarsegoldkid Posted March 28, 2008 Author Share Posted March 28, 2008 I know this is old but did anyone post a picture write up of the 08 retro fit for the cabin filter mentioned above? Well I did the 08 retro fit. I also tried to photo document the work but the pictures were not helpful in my opinion. Yes you have to tear the car apart but it really isn't to bad. There is a short instruction sheet that comes with the kit. The filter itself was a disappointment. Make your own with high quality filters from air conditioner filters(thin ones) from the hardware store. You'll see what I mean with kit in hand. Once the kit is installed replacement will be much easier but not as simple as changing the engine air filter. You still must wiggle into position, loosen a few fasteners and have a go at it. I think the kit is worth it, just make your own filter by using the tray as a template for size. I hope that helps. Link to comment Share on other sites More sharing options...
4wheeling Posted March 28, 2008 Share Posted March 28, 2008 Thanks for the reply. Two questions: 1) Is there a kit part number or do I order them individually? 2) If I am going to buy a better filter then do I need to order the OEM filter? Thank you. Link to comment Share on other sites More sharing options...
coarsegoldkid Posted March 29, 2008 Author Share Posted March 29, 2008 Use the numbers posted by Opie. You can skip the filter. Don't be in a rush and all dismantling comes easy. No forcing. Link to comment Share on other sites More sharing options...
4wheeling Posted March 29, 2008 Share Posted March 29, 2008 Thanks. Link to comment Share on other sites More sharing options...
jim1969 Posted August 12, 2008 Share Posted August 12, 2008 In addition to the above parts listed by Opie, I also needed: 2pc: 902510011 nut were do these go? Link to comment Share on other sites More sharing options...
jim1969 Posted August 12, 2008 Share Posted August 12, 2008 If you want a better fitting and better looking solution to the air filtration difficulty for your early 2005 (and 2006-2007 with the silly cloth cover) you can update all models to the new 2008 style. The 2008 style has an all new molded rear glove box section and a molded plastic door that covers the filter tray area that is held in place with 5 pop-its. Much cleaner looking and more solidly put together. It still takes about 10 minutes to change the filter but is a huge improvement over the 2005 non-design and the '06-'07 hacked-cloth design. I installed all the '08 parts in my early '05 today, took about 40 minutes total (I was taking my time). Didn't get any pic's because I wasn't sure it would work, but since it did I will also be ordering the same parts for my wife Legacy and will photo document the install at that time. 2008 Parts needed: Glove box back panel - 66208AG07A Air filtration access cover - 66241AG29A 5 Clip's (pop-its) - 909140037 Pocket cushion - 66153GA000 2 Tapping Scews - 904500025 and of course a replacement cabin filter - G3210AG000 Total cost (including the filter) was about $100, about the same price as the "Retro" kit from Subaru. Did you ever document you wife's legacy install? Just recieved all of the above parts. Link to comment Share on other sites More sharing options...
SBT Posted August 12, 2008 Share Posted August 12, 2008 Did you ever document you wife's legacy install? Just recieved all of the above parts. Was wondering this myself. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 16, 2008 Share Posted August 16, 2008 If you want a better fitting and better looking solution to the air filtration difficulty for your early 2005 (and 2006-2007 with the silly cloth cover) you can update all models to the new 2008 style. The 2008 style has an all new molded rear glove box section and a molded plastic door that covers the filter tray area that is held in place with 5 pop-its. Much cleaner looking and more solidly put together. It still takes about 10 minutes to change the filter but is a huge improvement over the 2005 non-design and the '06-'07 hacked-cloth design. I installed all the '08 parts in my early '05 today, took about 40 minutes total (I was taking my time). Didn't get any pic's because I wasn't sure it would work, but since it did I will also be ordering the same parts for my wife Legacy and will photo document the install at that time. 2008 Parts needed: Glove box back panel - 66208AG07A Air filtration access cover - 66241AG29A 5 Clip's (pop-its) - 909140037 Pocket cushion - 66153GA000 2 Tapping Scews - 904500025 and of course a replacement cabin filter - G3210AG000 Total cost (including the filter) was about $100, about the same price as the "Retro" kit from Subaru. Anybody have any pics of the 2008 parts just to see how much easier it is to change over the 2005-2006 silly cloth cover? I was thinking about doing this update but wanted to see if it is any easier Link to comment Share on other sites More sharing options...
jim1969 Posted August 16, 2008 Share Posted August 16, 2008 I have all this stuff in my trunk. Hoping for a write up here. Link to comment Share on other sites More sharing options...
Bimmer Posted August 17, 2008 Share Posted August 17, 2008 Anybody have any pics of the 2008 parts just to see how much easier it is to change over the 2005-2006 silly cloth cover? I don't have pictures, but here's the 2008 process: 1. Pry off the side cover from the dash board (where the dash meets the door). No screws. 2. Unscrew the glovebox hinge (one screw). Remove the glove box. 3. Tug out the owner's manual holder above the main glovebox compartment. No screws. 4. Remove the back of the glove box. Five screws. 5. Pop off the cover, and pull out the air filter element. The first time I did it, it took 15 minutes. Now I'm sure I could do it in less than five. Ben Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 17, 2008 Share Posted August 17, 2008 Sounds like it is pretty much the same process as the 2006 retro version with the paper and velcro cover, i wonder what is actually different here. I take the side cover off, I take the glove box off, pull the manual holder out, remove 3 screws holding bracket above paper cover, flip the paper cover up and pull out filter element. Is the only difference the it actually has a cover that you unscrew instead of a paper velcro door? If you could take some pictures of what it looks like with the glove box removed that would be great. Link to comment Share on other sites More sharing options...
outahere Posted August 23, 2008 Share Posted August 23, 2008 were do these go? sorry, I don't remember. I did the conversion a year ago. Link to comment Share on other sites More sharing options...
jim1969 Posted September 10, 2008 Share Posted September 10, 2008 I don't have pictures, but here's the 2008 process: 1. Pry off the side cover from the dash board (where the dash meets the door). No screws. 2. Unscrew the glovebox hinge (one screw). Remove the glove box. 3. Tug out the owner's manual holder above the main glovebox compartment. No screws. 4. Remove the back of the glove box. Five screws. 5. Pop off the cover, and pull out the air filter element. The first time I did it, it took 15 minutes. Now I'm sure I could do it in less than five. Ben could you post a pic of the 5 screws in the back of the glove box? Link to comment Share on other sites More sharing options...
jim1969 Posted October 6, 2008 Share Posted October 6, 2008 I am so pissed. I have all the necessary parts to convert my 05 to the 08 glove box. I got everything apart today. There is NO WAY the filter tray is coming out. It hits the right support bracket for the glove box where the screw goes in. The alignment is way off from the slot in the back of the 08 glove box. I had to reassemble my orignal setup. Link to comment Share on other sites More sharing options...
SBT Posted October 6, 2008 Share Posted October 6, 2008 I am so pissed. I have all the necessary parts to convert my 05 to the 08 glove box. I got everything apart today. There is NO WAY the filter tray is coming out. It hits the right support bracket for the glove box where the screw goes in. The alignment is way off from the slot in the back of the 08 glove box. I had to reassemble my orignal setup. So you bought Subaru's updated/upgraded filter "kit" and it won't fit the 05s? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jim1969 Posted October 6, 2008 Share Posted October 6, 2008 No. I bought all the pieces Opie listed when he converted his 05 glove box to the 08 glove box so that he could use the cabin filter. Now that I think of it, the retrofit kit was for certain VIN numbers. I have a very early build 05 ( I pre-ordered the car before it came out). Maybe they realized part way into 05 how far off the filter tray and air box were and adjusted them. There is no way my filter tray can come out of the air box. It's off to the right and higher than the slot it's supposed to come through on the back of the 08 glove box. Link to comment Share on other sites More sharing options...
SBT Posted October 6, 2008 Share Posted October 6, 2008 OIC. That's likely the reason and makes sense from an engineering/execution standpoint. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jim1969 Posted October 6, 2008 Share Posted October 6, 2008 now that I've got all the parts in my trunk............... Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 7, 2008 Share Posted October 7, 2008 No. I bought all the pieces Opie listed when he converted his 05 glove box to the 08 glove box so that he could use the cabin filter. Now that I think of it, the retrofit kit was for certain VIN numbers. I have a very early build 05 ( I pre-ordered the car before it came out). Maybe they realized part way into 05 how far off the filter tray and air box were and adjusted them. There is no way my filter tray can come out of the air box. It's off to the right and higher than the slot it's supposed to come through on the back of the 08 glove box. Jim if you dont get it to work and need your money back let me know Ill buy the parts from you. I was getting ready to do the same thing and my car is an 05 with the hackjob conversion from the factory. I was going to remove the Subaru hackjob and get these parts. Let me know if you have any luck if not email me at gregnauman@comcast.net. Ill wait to order my parts until I hear from you, that way you wont be out the cash. Link to comment Share on other sites More sharing options...
SBT Posted October 7, 2008 Share Posted October 7, 2008 GN - There are others in line ahead of you on this one. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 7, 2008 Share Posted October 7, 2008 Really I didnt see any posts to that affect. No problem though anyway I just thought I would help him out if he didnt want to be out the money. Ill just get them from www.thekingofparts.com then Link to comment Share on other sites More sharing options...
j255c Posted October 15, 2008 Share Posted October 15, 2008 I've had my car now for 2.5 years, and used to smoke in it a lot. You think i should do this? 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
