gtwannabe Posted December 19, 2006 Share Posted December 19, 2006 Got a CEL, and I know there is a way to read the codes on the dash. I found two sets of plugs under the dash above the fuse block. One set is green and the other is white. I also located the test connector under the rug on pass. side . So what now? I tried plugging them in different ways and got nothing. HELP! BTW the car is an 05 Legacy GT Link to comment Share on other sites More sharing options...
Spec B Posted December 19, 2006 Share Posted December 19, 2006 umm...I think you need an AP or some kind of physical connection to the ECU and a PC and software to be able to read the code. I don;t believe it just shows up on the dash. Link to comment Share on other sites More sharing options...
ilh Posted December 19, 2006 Share Posted December 19, 2006 White. And yes, it does just "show up on the the dash." http://www.legacygt.com/forums/showthread.php?t=2895 Link to comment Share on other sites More sharing options...
Impulse Posted December 19, 2006 Share Posted December 19, 2006 does this work on an 06 too? Link to comment Share on other sites More sharing options...
melayout Posted December 19, 2006 Share Posted December 19, 2006 They may have been removed post-05 model years, but if you find the "White" connectors, then it should work. I keed I keeed Link to comment Share on other sites More sharing options...
gtwannabe Posted December 19, 2006 Author Share Posted December 19, 2006 That worked. Had the right wires just didn't know about pushing the trip button on sweep. I got a code P0021 which is Intake Camshaft Position Timing to advanced. Probably the valve is sticking. Any idea if this is an easy fix? I hate to take it to the dealer if I can fix this. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 19, 2006 Share Posted December 19, 2006 IIRC, this "feature" was deleted in '06 so it only works with '05 cars. Link to comment Share on other sites More sharing options...
VTGT Posted December 20, 2006 Share Posted December 20, 2006 They may have been removed post-05 model years, but if you find the "White" connectors, then it should work. I've had trouble finding the white connectors. Are they hidden sometimes:lol: Link to comment Share on other sites More sharing options...
melayout Posted December 20, 2006 Share Posted December 20, 2006 I've had trouble finding the white connectors. Are they hidden sometimes:lol: If you find and connect them, but the CEL code does not show, then you may have launched some ICBMs. I keed I keeed Link to comment Share on other sites More sharing options...
ilh Posted December 20, 2006 Share Posted December 20, 2006 My white connectors were well hidden and taped way up above the fuse panel. I could have sworn they weren't in there, but they were. Link to comment Share on other sites More sharing options...
BDII Posted December 20, 2006 Share Posted December 20, 2006 Step 1: think Step 2: search Step 3: Post Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Spec B Posted December 20, 2006 Share Posted December 20, 2006 That worked. Had the right wires just didn't know about pushing the trip button on sweep. I got a code P0021 which is Intake Camshaft Position Timing to advanced. Probably the valve is sticking. Any idea if this is an easy fix? I hate to take it to the dealer if I can fix this. Wow...i have so much to learn! Glad you got it. Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted December 20, 2006 Share Posted December 20, 2006 Our 05 OBXT requires the green and white to both be plugged in for this to work. I dunno why it requires test mode...ah well it still works great. Link to comment Share on other sites More sharing options...
VTGT Posted December 21, 2006 Share Posted December 21, 2006 My white connectors were well hidden and taped way up above the fuse panel. I could have sworn they weren't in there, but they were. I guess i wasn't looking hard enough. Link to comment Share on other sites More sharing options...
