ToddMcF2002 Posted December 16, 2006 Share Posted December 16, 2006 I think I'm going to put in a Prosport mechanical boost guage. I've used vampire/crimp style taps in the past but I'm thinking of using the fuse box for easy disconnect. I was going to put this in fuse 20 (Cigarette lighter socket) - and crimp tap off of that for future guages / accessories. Thoughts? http://www.anythinggps.com/ProductImages/installations/Fuse.Tap.Mini.jpg Link to comment Share on other sites More sharing options...
TwinkE Posted December 18, 2006 Share Posted December 18, 2006 I have two of those for accessories right now. It works well. Link to comment Share on other sites More sharing options...
johnAWD Posted December 18, 2006 Share Posted December 18, 2006 Yes - good idea. Link to comment Share on other sites More sharing options...
Magic Posted December 18, 2006 Share Posted December 18, 2006 Those are Ideal Click Here everyday:redface: Link to comment Share on other sites More sharing options...
ToddMcF2002 Posted December 19, 2006 Author Share Posted December 19, 2006 Thanks for the input. I got the cubby assembly out and the panels under the stearing column removed. It was pretty strait forward so I see no complications doing this mod. Of course I havent bought the guage yet so I had to put everything back together! Link to comment Share on other sites More sharing options...
pattypat Posted December 20, 2006 Share Posted December 20, 2006 Just got done installing an auotmeter boost gauge. I used the same thing although I used the illumination fuse #16. Works great turns on and off with the headlights. I'm sure the cigarette light fuse will work just as well. Also do the prosports have a ground wire? If so the screw to the fuse panel works for a ground. Link to comment Share on other sites More sharing options...
scottmcphee Posted December 21, 2006 Share Posted December 21, 2006 So you put this in a spare fuse slot, or existing fuse slot and put that original fuse piggyback on this thing... ? Where'd you get it - any car shop? Link to comment Share on other sites More sharing options...
GTTuner Posted December 21, 2006 Share Posted December 21, 2006 Just make sure that circuit is able to handle the load your asking it to. Anything 15 amp or under you will be fine. If your trying to run in excess of 20-25 amps, find a good fused ignition output capable of 30 amps. Link to comment Share on other sites More sharing options...
pattypat Posted December 21, 2006 Share Posted December 21, 2006 Use the illumination slot that way the guage light turns on and off with your headlights. I put a 10 amp and 5 amp in the back of the fuse "extension". Link to comment Share on other sites More sharing options...
TwinkE Posted December 21, 2006 Share Posted December 21, 2006 So you put this in a spare fuse slot, or existing fuse slot and put that original fuse piggyback on this thing... ? Where'd you get it - any car shop? Yeah, any autoparts store should have one. Every time I go to autozone, I pick one up. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 21, 2006 Share Posted December 21, 2006 everytime? how many have you accumulated? Link to comment Share on other sites More sharing options...
TwinkE Posted December 22, 2006 Share Posted December 22, 2006 only 3. I don't go that often:) Link to comment Share on other sites More sharing options...
