sandra_dee Posted December 5, 2006 Share Posted December 5, 2006 i have a 92 suabru legacy sedan ands need to know how to check the engine codes.. Link to comment Share on other sites More sharing options...
rc0032 Posted December 5, 2006 Share Posted December 5, 2006 Get one of these from PepBoys (~$50) or go and they will read it for free http://www.ground-z.org/electronics/vehicle/obd002.jpg Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 5, 2006 Share Posted December 5, 2006 I would be surprised if you can find a OBDI scanner with the correct Subaru connector for $50. Your best bet is to go to PepBoys and ask them to scan it for you. I know that there are some model specific OBDI scanners for Ford and GM And Honda that are cheap, but I haven't seen a Subaru one yet. The one that rclark is showing appears to be an OBDII scanner. The Actron CP9150 with OBDI cables is like $250. http://actron.com/xcart/files/d_4_01.jpg http://ec2.images-amazon.com/images/P/B0007LEG2K.01._SS500_SCLZZZZZZZ Link to comment Share on other sites More sharing options...
rc0032 Posted December 5, 2006 Share Posted December 5, 2006 ^ you are correct I didnt see it was an '92 Link to comment Share on other sites More sharing options...
sandra_dee Posted December 5, 2006 Author Share Posted December 5, 2006 thanks for the help guys but seeing as i have no pep boys within a 150 miles area i guess im gonna have to find one of them The Actron CP9150 with OBDI cables...or something.. Link to comment Share on other sites More sharing options...
rc0032 Posted December 5, 2006 Share Posted December 5, 2006 Most auto parts stores will provied this service free Link to comment Share on other sites More sharing options...
Jon in CT Posted December 5, 2006 Share Posted December 5, 2006 Under the dash on the driver's side you'll find two green single-wire connectors. Connect them and then turn the key to the ON position (engine not running). Observe the flashes from the CEL. The number of long flashes is the 10s digit followed by the number of short flashes representing the units digit. For example, three long flashes followed by two short flashes indicates trouble code 32 (Oxygen sensor). Link to comment Share on other sites More sharing options...
sandra_dee Posted December 6, 2006 Author Share Posted December 6, 2006 cool.. thanks alot.. wouldnt happen to have a copy of the trouble codes on this site would ya..lol.. i live in a very remote area here and its over 35 miles to nearest auto parts store and its across a big mountain .dont want to chance the car that far again till i fix whatever is wrong.... Link to comment Share on other sites More sharing options...
Osei Posted December 6, 2006 Share Posted December 6, 2006 See if you can find either a Haynes or Chilton repair manual for your year. They have a list of most trouble codes inside. I have an 04, so my list wouldn't help. Amazon.com for mail order . O. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 6, 2006 Share Posted December 6, 2006 Have you tried this: http://bbs.legacycentral.org/ The legacygt.com website is mostly dedicated 05+ cars. You may find more help here. Link to comment Share on other sites More sharing options...
sandra_dee Posted December 6, 2006 Author Share Posted December 6, 2006 no havent tried that one but i did find a site that gave me the codes.. and it came up as..canister purge control solenoid... Link to comment Share on other sites More sharing options...
sandra_dee Posted December 6, 2006 Author Share Posted December 6, 2006 just to let you know you dont unhook these wires you have to hook them up because when i took the cover off under the dash it wasnt hooked up and as soon as i hooked it up and turned the key on it gave me my code.. so thanks for letting my know where to look.... Link to comment Share on other sites More sharing options...
Jon in CT Posted December 6, 2006 Share Posted December 6, 2006 just to let you know you dont unhook these wires you have to hook them up because when i took the cover off under the dash it wasnt hooked up and as soon as i hooked it up and turned the key on it gave me my code.. so thanks for letting my know where to look....Sorry about telling you to disconnect the green test mode connectors; I must have had a brain cramp when I was typing that. So you got a 35 trouble code. I wasn't too far off. For future reference, the page at http://www.psi3.co.uk/downloads/faultcodes.pdf has a large collection of Subaru trouble codes and their meanings (sometimes cryptic) for both OBD-I and OBD-II Link to comment Share on other sites More sharing options...
