sashadg1 Posted December 2, 2006 Share Posted December 2, 2006 The Tripometer blinks from whatever miles shown to ILL.5 and jumps back and forth to ILL.5 to ILL.6 Then back to the trip mileage. Also at the same time the the Heat temps screens are diming like I'm having a short out. Anybody have this problem? Dealer has pulled that area a while ago for unrelated problem? Link to comment Share on other sites More sharing options...
SubiGT Posted December 2, 2006 Share Posted December 2, 2006 ILL.5 and ILL.6 are the settings for your dash(and heater/radio) illumination. The selector is on the left lower instrument panel, down by the mirror control knob. When you move the selector, you will feel it "soft click" thru detents. Make sure it is left in one of these detents when you are done with it. If the dealer was in there recently, and the "shorting" continues after you now know what ILL.5 and ILL.6 mean, have the dealer fix the switch. Many Shuvs and Zuuls knew what it was to be roasted in the depths of the Slor that day, I can tell you! Link to comment Share on other sites More sharing options...
sashadg1 Posted December 2, 2006 Author Share Posted December 2, 2006 Awesome thanks for helping me figure this out. Thanks Scott Link to comment Share on other sites More sharing options...
SubiGT Posted December 3, 2006 Share Posted December 3, 2006 Np:) Many Shuvs and Zuuls knew what it was to be roasted in the depths of the Slor that day, I can tell you! Link to comment Share on other sites More sharing options...
cole46_51 Posted December 16, 2006 Share Posted December 16, 2006 thanks SubiGT, I noticed the same thing the other day and was wondering why it was doing this Link to comment Share on other sites More sharing options...
sashadg1 Posted February 14, 2007 Author Share Posted February 14, 2007 I saw it doing it again, I curious what this is. Of course it won't happen for the dealer. Oh well cole46-51 can you further explain what your did? Thanks Scott Link to comment Share on other sites More sharing options...
cole46_51 Posted February 14, 2007 Share Posted February 14, 2007 I saw it doing it again, I curious what this is. Of course it won't happen for the dealer. Oh well cole46-51 can you further explain what your did? Thanks Scott somehow the little knob on the left that controls the brightness of your dashboard has gotten stuck in between two of the notches, just turn it to a different notch and then back to the setting u like it @ and that should do the trick:icon_mrgr Link to comment Share on other sites More sharing options...
shtbxr22 Posted February 14, 2007 Share Posted February 14, 2007 It is a common problem for the ill. switch to flip between 5, and 6 in 05 Legacies. The dealer will replace the switch if it's under warranty,(if they can replicate it) or you can buy one and do it yourself. pretty simple. Link to comment Share on other sites More sharing options...
