dave g Posted December 2, 2006 Share Posted December 2, 2006 I am installing driving lights and need to run a wire for the switch. Does anyone know a convenient place to put the wire through? I have not got up under the dash for a look yet. Thanks. Link to comment Share on other sites More sharing options...
leftride Posted December 2, 2006 Share Posted December 2, 2006 search for some of the boost gauge installs they should provide some pics. I would suggest going through the driver's wheel-well. there is a rubber grommet there that you can punch though and it will put you right near the interior fuse box. That would probably be a good place to run for a switch. *vb gallery* Link to comment Share on other sites More sharing options...
dave g Posted December 2, 2006 Author Share Posted December 2, 2006 That's the ticket. I was searching on lights and everyone is installing boost gauges. Thanks. Link to comment Share on other sites More sharing options...
Guest subiecity Posted December 5, 2006 Share Posted December 5, 2006 open the hood, to the right side theres already a hole with like a piece of greyish rubber covering it,,,,i ran my wires for the demon eyes switches and the fog light switches there Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 30, 2009 Share Posted November 30, 2009 search for some of the boost gauge installs they should provide some pics. I would suggest going through the driver's wheel-well. there is a rubber grommet there that you can punch though and it will put you right near the interior fuse box. That would probably be a good place to run for a switch. Yes, and these are two other identical grommets on 5eat, and 1 or 2 identical on 5/6mt above the trans on either immediate side of the pitch stop mount where it connects to the frame. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted November 30, 2009 Share Posted November 30, 2009 There is a rubber gromet(sp?) on the firewall on the passenger side also, above the turbo-ish area. Link to comment Share on other sites More sharing options...
JonLGT Posted November 30, 2009 Share Posted November 30, 2009 I ran my wire for my amp through the grommet above the turbo also. Link to comment Share on other sites More sharing options...
D.dycle Posted December 3, 2009 Share Posted December 3, 2009 Does anyone know where I can get eye lids for my 09 hatch for a decent price ?? The best Link to comment Share on other sites More sharing options...
Visualfx Posted December 3, 2009 Share Posted December 3, 2009 search for some of the boost gauge installs they should provide some pics. I would suggest going through the driver's wheel-well. there is a rubber grommet there that you can punch though and it will put you right near the interior fuse box. That would probably be a good place to run for a switch. This is my suggestion as well. I quite a few wires through this grommet on my 06 Lgt. There is a good amount of room there and once you are in the wheel well there's plenty of room to work in, just a pain having to jack the car up and remove the wheel to do it. Link to comment Share on other sites More sharing options...
Jurgill06 Posted November 1, 2012 Share Posted November 1, 2012 This is my suggestion as well. I quite a few wires through this grommet on my 06 Lgt. There is a good amount of room there and once you are in the wheel well there's plenty of room to work in, just a pain having to jack the car up and remove the wheel to do it. Do you know if this is the same as just an 06 legacy 2.5i? and if so do you have a picture where this is located in the wheel well? Link to comment Share on other sites More sharing options...
