Ric Posted May 29, 2009 Share Posted May 29, 2009 I don't think the Australian market is big enough to get our own unique model McIntosh. Maybe you'rs is just an older model. Does it still have a cassette player in it? Link to comment Share on other sites More sharing options...
MGV101 Posted May 29, 2009 Share Posted May 29, 2009 I don't think the Australian market is big enough to get our own unique model McIntosh. Maybe you'rs is just an older model. Does it still have a cassette player in it? I'm gonna try it on mine later today. Not having much hopes though since the JDM head units radio are not in American or Australian mode but rather a Japanese mode where it only goes up to 99Mhz in FM so I think our units are different. Link to comment Share on other sites More sharing options...
Ric Posted May 29, 2009 Share Posted May 29, 2009 Hmmm, Australia is the same as all of Europe. Looks like Japan is a third "World Standard". Have a look at this convertor which shifts the Japanese frequencies up to the normal band. It has to be connected in series with the antenna lead: http://jaycar.com.au/productView.asp?ID=AR3100 Link to comment Share on other sites More sharing options...
JALEGACY Posted May 30, 2009 Share Posted May 30, 2009 Thanks. Those converters are very popular in Jamaica, but the radio stations are not as clean and when you try to use an mp3 player with an FM modulator you get a lot of distortion, and its very hard to find an unused frequency. That's why I was hoping the radio could switch the frequency range itself. Link to comment Share on other sites More sharing options...
JALEGACY Posted May 30, 2009 Share Posted May 30, 2009 Btw, my radio is the 6cd in-dash with the MD player, very similar to the one in the first post. Link to comment Share on other sites More sharing options...
MGV101 Posted May 30, 2009 Share Posted May 30, 2009 Tried it. It didn't work. =( Link to comment Share on other sites More sharing options...
MGV101 Posted May 30, 2009 Share Posted May 30, 2009 Btw, my radio is the 6cd in-dash with the MD player, very similar to the one in the first post. Yep. Mine looked exactly the same too. Link to comment Share on other sites More sharing options...
SubaruSVXCrazy Posted March 30, 2016 Share Posted March 30, 2016 (edited) it is in the head I would assume, when I plugged it in the radio portions worked. It was the HVAC that was goofy. I can't wait to get that bugger back here so I can play with it some more. With the schematics that are posted I am thinking that we should be able to "do this". I know this thread is old BUT in the assumption that this ever comes back up again I'd just like to make a suggestion. Can't you just pry off the Jdm hvac unit and pop on the USDM one and swap the buttons over before you snap it back into the Jdm trim instead of F-ing around with pin outs and what have you? Edited March 30, 2016 by SubaruSVXCrazy Link to comment Share on other sites More sharing options...
madrig Posted April 26, 2016 Share Posted April 26, 2016 no you can not . the usdm radio is one unit is now very easy to install a jdm unit on you car since a lot of info on the net is available. i have ausdm mcintosch unit plug in my car , thanks to SVxdc and all other menbers for all the post ! Link to comment Share on other sites More sharing options...
Shogun506 Posted April 28, 2016 Share Posted April 28, 2016 no you can not . the usdm radio is one unit is now very easy to install a jdm unit on you car since a lot of info on the net is available. i have ausdm mcintosch unit plug in my car , thanks to SVxdc and all other menbers for all the post ! And what do you think of the Mcintosh system? I've seen a couple and had an opportunity to buy everything from just the headunit to the entire system of speakers and subwoofers. What do you have and what do you think of it vs stock? Link to comment Share on other sites More sharing options...
WRX USA Posted April 28, 2016 Share Posted April 28, 2016 And what do you think of the Mcintosh system? I've seen a couple and had an opportunity to buy everything from just the headunit to the entire system of speakers and subwoofers. What do you have and what do you think of it vs stock? If you buy the speakers you will also need the front doorcards since there are mids that we don't have and you'll want the grille properly placed. Link to comment Share on other sites More sharing options...
madrig Posted April 28, 2016 Share Posted April 28, 2016 Shogun506 i have 2009 mcintosh and amps . im happy with it ! it s all depend what you expect and what you pay for . in my head its sound better than oe unit , but not big difference , i have oem lgt speakers so i need speakers upgrade why i went this way ? i like the oem look better than aftermaket unit , it fill up the dash better the price , i only wanted to ad Auxiliary jack , same price if you buy a 2009 usdm oem unit and way cheaper than buy jdm hvac and aftermaket radio for sure you will have better sound with aftermarket radio and way more option but i can still separate the hvac from my mcintosh and add an aftermaket unit ! if you can score an unit , amps and all speakers that will be great ! the system is one more tweeter on mirrors cover and a 4 inch in the panel door . like say wrx usa need panel door grille or work something aftermarket . Link to comment Share on other sites More sharing options...
Shogun506 Posted April 29, 2016 Share Posted April 29, 2016 Merci Madrig, J'ai un jazzy-mod alors je croix que je n'ai pas besoin d'un mcintosh pour la aux-in, et j'ai des polk 651/6501 mais il n'est pas encore dans la voiture. I'm just always trying to spend more money Link to comment Share on other sites More sharing options...
KhadzTrini Posted April 29, 2016 Share Posted April 29, 2016 I have a headunit just like this one (2009 mcintosh). Sadly it didn't come with the aux in jack but came with the aux button on the headunit. How can I install one? Was looking at the gram units for aux and bluetooth but not sure if it will work with my headunit. I want something to plug in and play. Link to comment Share on other sites More sharing options...
madrig Posted April 29, 2016 Share Posted April 29, 2016 pas de probleme Shogun506, le plaisir de modifier ne s arrete jamais !! i m always looking to buy items on ebay that i dont need !!hehe! Link to comment Share on other sites More sharing options...
thomas1657615996 Posted October 1, 2019 Share Posted October 1, 2019 Sorry to bump an old thread, but need some info. I understand the JDM Mcintosh HU bolts up with no problem to a USDM car, but, does it look ok? I mean, are there no gaps because of RHD / LHD difference? Thanks Link to comment Share on other sites More sharing options...
Brunzo Posted October 16, 2019 Share Posted October 16, 2019 I had McIntosh in my LHD Legacy. It does not fit plug and play. It needs some small modification (with dremel tool) of inner panel (to accept alarm switch) and some modification bottom of hvac unit to match with ash tray. Side trim parts have a tiny gap anyway, but not very noticeable, check second picture left top corner: These are old pics, i sold the car 2 years ago, but this JDM McIntosh stands in my garage still along with JDM cluster. Link to comment Share on other sites More sharing options...
thomas1657615996 Posted October 16, 2019 Share Posted October 16, 2019 I had McIntosh in my LHD Legacy. It does not fit plug and play. It needs some small modification (with dremel tool) of inner panel (to accept alarm switch) and some modification bottom of hvac unit to match with ash tray. Side trim parts have a tiny gap anyway, but not very noticeable, check second picture left top corner: These are old pics, i sold the car 2 years ago, but this JDM McIntosh stands in my garage still along with JDM cluster. Thanks for the info. I've sent you a pm . Link to comment Share on other sites More sharing options...
