Reverend Posted March 20, 2007 Share Posted March 20, 2007 Sure, will do. I'm leaning towards installing the mic up at the top left corner of the headliner & the button right by the gear selector & my V1 remote audio unit, but we'll have to see how they work tested in those locations before I actually install them there... Now that I'm thinking about it, I wonder if you can use the same mic that's used for the Parrot Bluetooth kits. It would be silly to have two microphones in the car, if you can make one work for both systems. Link to comment Share on other sites More sharing options...
ama0787 Posted March 21, 2007 Share Posted March 21, 2007 I was thinking our navigation could work with blue tooth is that not the case? I havent researched but thought I saw it and thought it was another of the unused navigations functions Link to comment Share on other sites More sharing options...
TwinkE Posted March 21, 2007 Share Posted March 21, 2007 Sure, will do. I'm leaning towards installing the mic up at the top left corner of the headliner & the button right by the gear selector & my V1 remote audio unit, but we'll have to see how they work tested in those locations before I actually install them there... I've got mine right above the drivers visor, sticking out a little bit and the mic doesn't work for crap. No one I know can get it to do anything, it just randomly chooses something to do. I've tried moving it but still no dice. For the button, I unscrewed my sidrive panel and ran the wire behind it and put it back together. Link to comment Share on other sites More sharing options...
badfish11 Posted March 22, 2007 Share Posted March 22, 2007 Wow great feature, its crazy that Subaru wouldn't include this as standard with navi. So can you enter destinations while driving with voice commands? Link to comment Share on other sites More sharing options...
Reverend Posted March 22, 2007 Share Posted March 22, 2007 Subaru probably disabled that too, because people can't talk and drive at the same time. Link to comment Share on other sites More sharing options...
ERLoft Posted March 22, 2007 Share Posted March 22, 2007 Subaru probably disabled that too, because people can't talk and drive at the same time. LMAO I do know some folks who proably shouldn't talk and drive. Or listen to music and drive. Or chew gum and drive. Or just plain drive. Sad that we're tuned to the LCD... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
XiiiXiii Posted March 29, 2007 Share Posted March 29, 2007 The only thing is I wish it muted the radio when I hit the mic button. I usually hit the mute on the steering column first. If the radio isn't too loud it does work though. Hi all, I've been lurking for the past week and just recently purchased/pickedup my Spec.B Good read on the hacks/addons you guys have been doing to the Nav system. I just wanted to comment on this subject and I'm going to work on adding this feature in. When I get a little time (and feel less guilty for hacking up a new car) I'm thinking of taking the wire for the steering wheel mute button and run it through a small circuit board inline with the mic button. It should be a straight foward design, {push mic button -> pushes the radio's mute once, release mic button -> radio's mute is pushed once more} I've hacked a lot of electronics in my time and this just seems something fun/useful to create. Hopefully I can find parts to attach to stock harnesses so that I don't have to cut apart harnesses. Would cost a little more in parts, but would make for easy installs. If/when I finish this project I'll probably post up some tutorials on how to make. Wish me luck. Link to comment Share on other sites More sharing options...
Jon in CT Posted March 29, 2007 Share Posted March 29, 2007 When I get a little time (and feel less guilty for hacking up a new car) I'm thinking of taking the wire for the steering wheel mute button and run it through a small circuit board inline with the mic button. It should be a straight foward design, {push mic button -> pushes the radio's mute once, release mic button -> radio's mute is pushed once more} I've hacked a lot of electronics in my time and this just seems something fun/useful to create. Hopefully I can find parts to attach to stock harnesses so that I don't have to cut apart harnesses. Would cost a little more in parts, but would make for easy installs. If/when I finish this project I'll probably post up some tutorials on how to make. Wish me luck.You'd better check out a wiring diagram first. You sound as if you think there's a separate wire connecting each button to the radio. That's not the case. Each button changes the resistance on a circuit, so there's only two wires connecting all the buttons to the radio. See http://www.legacygt.com/forums/showpost.php?p=677144&postcount=102 for resistance values. Link to comment Share on other sites More sharing options...
XiiiXiii Posted March 29, 2007 Share Posted March 29, 2007 Wow, thanks for the info. That will save me time when dissecting and studying the system. This just makes the project even more interesting to do Link to comment Share on other sites More sharing options...
ERLoft Posted March 30, 2007 Share Posted March 30, 2007 I haven't had time to wire the mic & button where I want it, but I have gotten it hooked up and boy, it's a bit rough at times. Mistakes commands at times and for the life of me I can't get 'Enter Destination' to work at all... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Reverend Posted March 30, 2007 Share Posted March 30, 2007 So far it doesn't sound like you're very impressed with it. Link to comment Share on other sites More sharing options...
ERLoft Posted April 2, 2007 Share Posted April 2, 2007 So-so. I'll have to see how I like it once the mic and button are placed. I can say I don't like that I'm stuck with the lame female voice. I like Alfred much better! 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Jon in CT Posted April 2, 2007 Share Posted April 2, 2007 His name is Nigel. You lose the option to set the voice used? Link to comment Share on other sites More sharing options...
ERLoft Posted April 2, 2007 Share Posted April 2, 2007 No, Alfred (Nigel's not bad either, but the wifey already named him) still gives directions. Bizznatch confirms your voice commands and asks questions if there's any problems... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
WiseYoda Posted April 21, 2007 Share Posted April 21, 2007 Any pics on these installs... or thoughts now that you have been using it for a while? I was thinking about installing this... it seems simple and quick, but if the functionality isn't that great, I'll stay away. [FONT=Arial][SIZE=1][COLOR=Navy][B]"Do, or do not. There is no 'try'." -Jedi Master Yoda (I believe he was talking about the search tool)[URL="http://specb.jerkerstudios.com/"][/URL] [/B][/COLOR][/SIZE][/FONT] Link to comment Share on other sites More sharing options...
phoenix96 Posted April 23, 2007 Share Posted April 23, 2007 Any pics on these installs... or thoughts now that you have been using it for a while? I was thinking about installing this... it seems simple and quick, but if the functionality isn't that great, I'll stay away. It's a nifty add-on, but I'm not sure how much it's really worth by itself since the navigation system isn't integrated with the stereo or climate control and doesn't have bluetooth, etc. I put it in our VDC while doing a bunch of other things but I wouldn't have bothered pulling apart the interior for just the nav microphone. phoenix96 2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX 2006 Outback 3.0R VDC · 2009 Forester 2.5X 2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10 Link to comment Share on other sites More sharing options...
WiseYoda Posted April 23, 2007 Share Posted April 23, 2007 It's a nifty add-on, but I'm not sure how much it's really worth by itself since the navigation system isn't integrated with the stereo or climate control and doesn't have bluetooth, etc. I put it in our VDC while doing a bunch of other things but I wouldn't have bothered pulling apart the interior for just the nav microphone. Cool. Thanks for the reply. If I go down the OEM XM Radio route, perhaps I can install it then. If not, it sounds like something I can do without. [FONT=Arial][SIZE=1][COLOR=Navy][B]"Do, or do not. There is no 'try'." -Jedi Master Yoda (I believe he was talking about the search tool)[URL="http://specb.jerkerstudios.com/"][/URL] [/B][/COLOR][/SIZE][/FONT] Link to comment Share on other sites More sharing options...
ERLoft Posted April 23, 2007 Share Posted April 23, 2007 Yeah, I'll have to say it's just okay. A few features short of being really useful... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
WiseYoda Posted April 23, 2007 Share Posted April 23, 2007 Yeah, I'll have to say it's just okay. A few features short of being really useful... As it is... is it $65 useful? [FONT=Arial][SIZE=1][COLOR=Navy][B]"Do, or do not. There is no 'try'." -Jedi Master Yoda (I believe he was talking about the search tool)[URL="http://specb.jerkerstudios.com/"][/URL] [/B][/COLOR][/SIZE][/FONT] Link to comment Share on other sites More sharing options...
TwinkE Posted August 8, 2007 Share Posted August 8, 2007 I was having "trouble" with it never recognizing my voice commands. Ever. I got the updated Nav discs this week and decided to try the mic once more and it started recognizing everything I said. I'm not pissed off about wasting money on this anymore. CN: Try the new nav update if you have problems with the voice recognition. Link to comment Share on other sites More sharing options...
camber Posted August 9, 2007 Share Posted August 9, 2007 Gah... I tried to figure out what was they difference between my version v1.1 and v2 discs were and I could not find anything. It's nice to know that Kenwood/Subaru/Denso decided to update functionality of a feature NAV that can't even be used by any stock Subaru. Yet, they don't update any of map infomation! Link to comment Share on other sites More sharing options...
spolkyc Posted August 12, 2007 Share Posted August 12, 2007 As long as the Nav is the same, which I believe it is, the mic should work. I will be testing traffic hopefully this weekend. I will open a new thread for that. So what ever happened to the traffic unit. Did it work? I have been searching around and have been unable to find anyone who has had it work or not. added It looks like we need to remove a knock out on the nav unit. Is there anything behind it? It looks like there are 3 places covered. The TMC Receiver, Active Speaker & Audio/Video Output. Link to comment Share on other sites More sharing options...
carrata Posted August 12, 2007 Share Posted August 12, 2007 subscribe Link to comment Share on other sites More sharing options...
grbspecb Posted August 13, 2007 Author Share Posted August 13, 2007 I have not had a chance to open the dvd unit up and see if the plug is there I remember reading the unit may be a 3100 and not a 3200 and does not even have the plugs. hopefully this weekend i can take a look. if anyone knows if the plug is behind the knockout that would be awesome. Link to comment Share on other sites More sharing options...
Origtopcat Posted August 13, 2007 Share Posted August 13, 2007 I read through the owner's manual and noticed a 2d/3d view (like nissan and toyota offer)... anyone know if we can tap into it? I tried to activate the 3d map. Does not seem to work for the SOA version. Not sure if the issues is related to the DVD's or if the navigation firmware is locked down. The European version works. Nemo me impune lacessit Link to comment Share on other sites More sharing options...
