sweeper Posted January 3, 2008 Share Posted January 3, 2008 I've just realized this problem...setting cruise @ 80 MPH, shuts down randomly. Any updates on a fix? I have a TDC Stg2 tune, w/ the AP V2... Apparently, the car was already reflashed by the dealership w/ the updated cruise control fix. I did run the code check and the neutral switch code has been tripped. Has anyone had any luck in the long term with a shorter gasket? Also, from reading above, is is true that I'm not getting the full stage 2 power at the low end? That sux... Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 3, 2008 Share Posted January 3, 2008 It doesn't matter what rom the dealer flashed. The APV2 will overwrite the rom. Link to comment Share on other sites More sharing options...
sweeper Posted January 3, 2008 Share Posted January 3, 2008 It doesn't matter what rom the dealer flashed. The APV2 will overwrite the rom. So when you're talking about the 521 and 522 rom's sucking for tuning, are you talking about tuning with 'open' tuning tools other than the AP? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 3, 2008 Share Posted January 3, 2008 Also, from reading above, is is true that I'm not getting the full stage 2 power at the low end? That sux... No, you should be getting the same power as the 05 equivalent tune because the Cobb rom is based on the non-WGDC time delay rom. Link to comment Share on other sites More sharing options...
sweeper Posted January 3, 2008 Share Posted January 3, 2008 Cool, one less thing to worry about, thanks for clarifying...now how do I fix this damn cruise control! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 3, 2008 Share Posted January 3, 2008 So when you're talking about the 521 and 522 rom's sucking for tuning, are you talking about tuning with 'open' tuning tools other than the AP? Yes. Cobb rom should be based on the older 510N rom without the WGDC time delay. merchgod modified my 522N rom so that it works just fine. For the OBXT, it might be different ... 510R? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 3, 2008 Share Posted January 3, 2008 Cool, one less thing to worry about, thanks for clarifying...now how do I fix this damn cruise control! 1. Buy a tactrix cable. 2. Revert back to your factory "fixed" rom. The APV2 should have it stored in memory. 3. Check your factory rom id to make sure that it is the "fixed" rom. 4. Email factory "fixed" rom to merchgod and ask him to eliminate the WGDC time delay in it. 5. Contact Legend and ask him to borrow his stage 2 rom. His stage 2 rom is setup for high altitude. I helped him tune his car so I have a copy of one of his older versions which I can email to you as well. I don't know what he has done to it since I last spoke to him. 6. Copy tables from Legend's rom to your factory fixed-merchgod modified rom. 7. Reflash your ecu. 8. Datalog and post or email me your datalogs. 9. Tweak rom. 10. Reflash rom. Link to comment Share on other sites More sharing options...
sweeper Posted January 3, 2008 Share Posted January 3, 2008 Holy sh*t...that sounds like a lot of work! Maybe I'll just keep my foot on the pedal... Thanks for your help! Link to comment Share on other sites More sharing options...
CombatCQB Posted January 10, 2008 Share Posted January 10, 2008 Aren't you asking him to dump the AP and go with a fixed tune? I remember fixing my problem by replacing the neutral switch washer with a thinner one. I actually dremeled it thinner instead of finding a new washer. Link to comment Share on other sites More sharing options...
sweeper Posted January 11, 2008 Share Posted January 11, 2008 That sounds more like it! Has that worked in the long term? Could someone tell me where the switch is? Thanks! Link to comment Share on other sites More sharing options...
CombatCQB Posted January 12, 2008 Share Posted January 12, 2008 If you can, try data logging your neutral switch to be sure this is the problem. You just need a laptop, tatrix cable and download the free SW at OpenECU http://www.legacygt.com/forums/showthread.php?t=30814&highlight=cruise+control+washer Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2008 Share Posted September 13, 2008 Bump this oldie... I got this problem after going to a Cobb Street Tuner map (510n based). Fix was simple for me - I just disabled P0852 cel (and P0851 for a good measure) regarding the neutral switch and all is good. No CEL, cruise control works as intended, even disengages correctly when the shifter is moved into neutral (without clutch, as depressing clutch pedal itself disengages cruise control). Link to comment Share on other sites More sharing options...
robinlsb Posted September 13, 2008 Share Posted September 13, 2008 Bump this oldie... I got this problem after going to a Cobb Street Tuner map (510n based). Fix was simple for me - I just disabled P0852 cel (and P0851 for a good measure) regarding the neutral switch and all is good. No CEL, cruise control works as intended, even disengages correctly when the shifter is moved into neutral (without clutch, as depressing clutch pedal itself disengages cruise control). You are kidding right?????? You mean this simple fix was available all along and neither CoBB or anybody else figured it out!??????? Unclemat for President!!!!!!!:) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2008 Share Posted September 13, 2008 No, I am not kidding. That's exactly what I did. I forgot reading about these issues... so when I saw the CEL after flashing Cobb map, I just killed it (with romraider/ecuflash) without thinking much. It works. Then I read the whole drama here and indeed I am wondering why was it such a big deal? EDIT: I drove the car only for maybe 7 minutes. I dunno if there are any downsides to killing that CEL, but I did not notice anything abnormal. Link to comment Share on other sites More sharing options...
praedet Posted June 12, 2012 Share Posted June 12, 2012 Bumping this, and trying out unclemat's fix as this came back on me recently... Link to comment Share on other sites More sharing options...
ktmrider Posted June 22, 2012 Share Posted June 22, 2012 I had this happen last year, here is my resolution: http://www.romraider.com/forum/viewtopic.php?f=26&t=7707 Basically was not getting the CEL so I couldn't turn it off, updated to an 06MY map and voila no shutoff. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 20, 2013 Share Posted March 20, 2013 No, I am not kidding. That's exactly what I did. I forgot reading about these issues... so when I saw the CEL after flashing Cobb map, I just killed it (with romraider/ecuflash) without thinking much. It works. Then I read the whole drama here and indeed I am wondering why was it such a big deal? EDIT: I drove the car only for maybe 7 minutes. I dunno if there are any downsides to killing that CEL, but I did not notice anything abnormal. 7 Minutes... Did this really really work for anyone? Link to comment Share on other sites More sharing options...
f1anatic Posted March 21, 2013 Share Posted March 21, 2013 Is this an issue so many years later ? I mean I have the cruise control issue myself, any speed higher than 73ish- and it will disengage for no reason after only a few minutes. It is more of a bother than a real problem. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 21, 2013 Share Posted March 21, 2013 Is this an issue so many years later ? I mean I have the cruise control issue myself, any speed higher than 73ish- and it will disengage for no reason after only a few minutes. It is more of a bother than a real problem. Since I am stuck on 510N because of AccessPort I, it is for me. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 25, 2013 Share Posted March 25, 2013 For the record it _doesn't_ work. Confirmation bias. Looks like Accessport I users have to move on. Link to comment Share on other sites More sharing options...
