Engine performance
I've heard that Boxer engines don't give their full performance until they've done quite a few miles.
I've got a 3-litre Liberty (Legacy to all non-Aussies) that's up to 7000km (4400 miles) and standing-start acceleration doesn't seem as quick as it should be, looking at the performance figures in the magazines. In particular, acceleration up to 60km/h (40mph) seems very sedate...
The 3.0 6-cyl develops most of its power up high in the RPM band. If you want rapid acceleration, you will have to rev it out. Otherwise, it will feel soft. Also, if you have the auto trans, the car is going to feel sluggish on standing starts in comparison with what a manual trans is capable of. Midrange power should be similar for both types of trans (e.g. overtaking on the highway).
It's true Subaru engines seem "tight" from the factory and supposedly take 10K kilometers or so to reach their best power. The difference is probably not going to be dramatic, though, just noticeable.
It should be noted that, from what I've seen, the 0-60mph numbers (or 0-100kph) are usually done with an AWD launch. The STi, for example, is listed as a hair over 5s, (vs. 4.6 or so listed by the Subaru brochures), but in order to get that, you're going to have to sacrifice some clutch life. :)
Thanks to all who replied for the info. This seems to confirm what I'd heard that they are tight from the factory. The 6 cylinder engine has a fantastic exhaust note but a little more low-down torque would make it perfect.
For engines that need more help just off idle, supercharging usually helps more.
Turbocharging comes on later, so tends to supplement mid-range and/or top end.
It would be interesting to bolt a recently announced rotrex two-speed supercharger to an H6. Cobb has already done it with a regular rotrex unit...
I think block might be to long for normal turbo configurations.
Needs 1 turbo per cylinder bank.
Somebody better tell PDX Tuning and the other tuners out there that are doing exactly that.
That said, if the OP is looking for more torque down low, then a supercharger might be more the ticket.
Ich bin echt viel netter, wenn ich nuechtern bin. Echt!
