jaymesbry Posted November 25, 2006 Share Posted November 25, 2006 Well this is the one part ive always been confused about.. (always had aftermarket decks anyway..) Ill be using the stock headunit, and im trying to figure out if i should go with this EQ here http://www.arcaudio.com/arc-05/processors/meq.htm or if I should just go with some of the David Navone LOCs? and if I do go LOC, would i need one for the four channel amp and one for the subwoofer amp? it would be for the following setup that im planning.. PG Xenon 100.4 PG Xenon 600.1 CDT EuroSport 620 SS Exact 12 (I know theyre OLD, but I still have 2 of them from my last set up, and i wanna see how long each of them lasts under the 600.1 ) so for this case, what do you guys recommend! Thanks Link to comment Share on other sites More sharing options...
Magic Posted November 26, 2006 Share Posted November 26, 2006 How much does that ARC piece Cost. YOu can get a CS for about $400 Click Here everyday:redface: Link to comment Share on other sites More sharing options...
lucas569 Posted November 26, 2006 Share Posted November 26, 2006 if u need the navone loc i got one fs $20 Link to comment Share on other sites More sharing options...
RezaLaleh Posted November 26, 2006 Share Posted November 26, 2006 James, Let's talk about power Mods .... SubaruBoxer.com Link to comment Share on other sites More sharing options...
bmorrisj Posted November 26, 2006 Share Posted November 26, 2006 you would need a LOC either way... that EQ most likely only accepts low level line inputs (RCAs) Link to comment Share on other sites More sharing options...
Boulderguy Posted November 26, 2006 Share Posted November 26, 2006 Yes, you'll still need the LOC. Plus the EQ only takes 2 channels, not four, so you're losing the fader capacity. So only a 2-ch LOC. Link to comment Share on other sites More sharing options...
jaymesbry Posted November 27, 2006 Author Share Posted November 27, 2006 weak.. oh well i think ill just wait till TDC comes out with whatever mod theyre coming up with.. then i can get that double din touchscreen i want.. Link to comment Share on other sites More sharing options...
