acooper5 Posted November 22, 2006 Share Posted November 22, 2006 I did a search and it was to my relief that others have had this same problem. I bought an Sti up and was very excited to get it installed. It has been a while since I have done an uppipe install, so it took me about 8 hours, with all the work getting the uppipe in and the banging around i finally got it. Well I thought I did, check for leaks and everything seemed fine. The next day I had smoke coming out of my hood scoop. I thought it was a leak, although I heard nothing, I checked the car once I stopped and turned the car off, it still smoked, no exhaust leak. I put the car on ramps and removed the heat shield started and left the car running for about 10 minutes and found that there is a LEAK just about where the uppipe and the exhasut manifold connect. I think it is the valse cover seal. It is just a small sllllloooww drip but enough to cause the smell and the smoke. I know a number of you have experienced this. If I put my stock downpipe back on and remap back to stock, will I be able to get this fixed under warrenty? If I have to pay I will. I took it to a family mechanic and he said he cant guarenttee that it wont leak again and he doesnt want to do it, he said take it to subaru and try to get it under warrenty. What do you guys think? How much will this cost me? I have heard from 150-200. I dont think that is too bad, but if I could get it under warrenty I will. I have an appointment on Friday morning to get it checked out and hopefully fixed. Thanks and have a good Thanksgiving! Semper Fi. Link to comment Share on other sites More sharing options...
automaticsti Posted November 22, 2006 Share Posted November 22, 2006 you probably hit the edge of the valve cover gasekt while fishing the new up pipe in or forcing the old one out. Seen it a hundred times. IDK as long as you revert it to stock you should get it under warrenty. Link to comment Share on other sites More sharing options...
acooper5 Posted November 22, 2006 Author Share Posted November 22, 2006 umm, I plan on leaving the sti up in, I will put everything else back to stock, do you think they will notice the STi up? or even my perrin crank pulley Semper Fi. Link to comment Share on other sites More sharing options...
automaticsti Posted November 22, 2006 Share Posted November 22, 2006 nah, you should be fine as long as they dont read this thread Link to comment Share on other sites More sharing options...
PGT Posted November 22, 2006 Share Posted November 22, 2006 halfmoon or crescent seal or somethig like that. fairly common. Either that, or you knocked the return line loose (which is ALOT worse and you'd know). Link to comment Share on other sites More sharing options...
acooper5 Posted November 23, 2006 Author Share Posted November 23, 2006 thanks ASTi and PGT, we will see what Manassas Subaru has to say on Friday morning...as for me, I am going to put the stock downpipe back in and revert to stock map for now Semper Fi. Link to comment Share on other sites More sharing options...
VTGT Posted November 23, 2006 Share Posted November 23, 2006 subscribe. Link to comment Share on other sites More sharing options...
PhilT Posted November 23, 2006 Share Posted November 23, 2006 thanks ASTi and PGT, we will see what Manassas Subaru has to say on Friday morning...as for me, I am going to put the stock downpipe back in and revert to stock map for now ManAssAs Subaru ? You have to be joking right ??? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
acooper5 Posted November 24, 2006 Author Share Posted November 24, 2006 thats right ManASSas subaru, just dropped my car off hopefully they will cover it under warrenty. We will see I am waiting for them to call, it shouldnt be that hard for them to "figure out" what it is, I told them exactly what it is. Semper Fi. Link to comment Share on other sites More sharing options...
wukindada Posted November 24, 2006 Share Posted November 24, 2006 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
acooper5 Posted November 24, 2006 Author Share Posted November 24, 2006 well, it took them 5 hours this morning but got it back!! WARRENTY COVERED!!! that was great news, looks like the mech left alot of oil in that general vacinity so, It was still burning alot off when I drove it home. Hopefully it will go away and hopefully it is done right, I will check when the engine cools off. If it is then time to go back to Stage 2 and put my downpipe on . Semper Fi. Link to comment Share on other sites More sharing options...
fweasel Posted November 24, 2006 Share Posted November 24, 2006 well, it took them 5 hours this morning but got it back!! . And their diagnosis was... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted November 24, 2006 Share Posted November 24, 2006 ^valve cover gasket im sure i had oil that dripped everywhere too after doing the gasket, you cant help but splash it everywhere... just add some more in about a day or two...i think i had under a 1/4 qt come out on mine Link to comment Share on other sites More sharing options...
acooper5 Posted November 24, 2006 Author Share Posted November 24, 2006 Thanks AWDBoost, good advice that is what I am going to do. Here is what the repair ticket said: "gasket rocker cover RH, NO 20, found right side valve cover gasket leaking onto exhaust. Replaced gasket & spark plug tube gaskets." All was repaired under warrenty. Semper Fi. Link to comment Share on other sites More sharing options...
