trubspecb Posted November 22, 2006 Share Posted November 22, 2006 I have a 2006 3.0r SpecB 5 speed auto legacy in the UK. when i reverse out of a parking space, and apply maximum left hand steering lock, the left front wheel judders; almost as if i have run over a stone. it has done this a few times now, in the same place and circumstances. there was a service bulletin 02-98-05 (dated 12/01/05) to cover something like this, on 2005 cars, but i would have hoped they would have sorted it on the 2006 cars? before i take it to the dealer i wondered if anyone else had experienced this on a 2006 or 2007 car? thanks in anticipation. Link to comment Share on other sites More sharing options...
crash Posted November 22, 2006 Share Posted November 22, 2006 Do you have a link to the TSB? I've been noticing this here recently (cause I've been parking in different spot at home and having to reverse more). Link to comment Share on other sites More sharing options...
captainmorgan Posted November 22, 2006 Share Posted November 22, 2006 bad knuckle? Link to comment Share on other sites More sharing options...
GTsleeper2 Posted November 22, 2006 Share Posted November 22, 2006 its possible the 1/2shaft, outer cv joint is bad. it could bind & make this happen. put at the same should make a noise in conjuction of movement Link to comment Share on other sites More sharing options...
Xenonk Posted November 23, 2006 Share Posted November 23, 2006 it's also putting a lot of stress to put your steering at full lock, that can wear out your pump.. subarus (and many newer cars) dont like it when you put the steering at full lock.. I know a few people who have blown their power steering from doing donuts in the snow by having the wheel locked for too long of periods. Keefe Link to comment Share on other sites More sharing options...
trubspecb Posted November 23, 2006 Author Share Posted November 23, 2006 thanks for your thoughts. the car drives fine apart from this judder on full lock in reverse. i read the handbook again last night and i wondered if it could be a combination of the ABS and VDC self testing at start up and first movement? the book warns you may feel strange movements through the steering and brakes when these systems self test. i will try the same scenario with a running car i.e pull into the parking space and then immediately back out, on full lock ,to see if it occurs then? any more thoughts welcomed? Link to comment Share on other sites More sharing options...
Breeze Posted July 8, 2007 Share Posted July 8, 2007 Did you ever fix this? My car does it and I am told by subaru there is a sensor on the steering which disengages the centre dif. Sometimes this goes bad and you then get diff wind up on full lock in reverse (it affects the forward steering too). Link to comment Share on other sites More sharing options...
Jerboa113 Posted July 9, 2007 Share Posted July 9, 2007 huh, I thought I was crazy.. mine does this every now and then.. its as if I'm running over several small bumps as I back up. Not every time. its done it twice in 6 months and I never pul through parking really anymore so I back out a LOT.. oif it does it more I will have to make a service call on it. consider this a lurking subscription also "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
Breeze Posted July 9, 2007 Share Posted July 9, 2007 Hmmm, Done some more investigation, got under the car everything seems OK, checked the diagnostics and got a C0119 - G sensor signal abnormal. I will pull out the centre console and check out the sensor (and swap it with the one in my sedan) and see if it makes a difference. BTW mine is a 5MT Bspec Link to comment Share on other sites More sharing options...
jp51mustang Posted November 15, 2008 Share Posted November 15, 2008 What was the final outcome on this one? My 07 spec b did this to me today. Both forward and reverse; very slow left turn in and out of a parking spot. Link to comment Share on other sites More sharing options...
Vwown3d Posted November 16, 2008 Share Posted November 16, 2008 center diff maybe. slow speed, full turn, its the plates in the diff binding up. Happened to my 05 2.5RS Link to comment Share on other sites More sharing options...
dammitjim Posted November 16, 2008 Share Posted November 16, 2008 Dont turn the wheel that far? Link to comment Share on other sites More sharing options...
jp51mustang Posted November 16, 2008 Share Posted November 16, 2008 It doesn't seem to do it all the time and I'm almost positive I wasn't completely full lock. odd Link to comment Share on other sites More sharing options...
