Nachowang Posted November 21, 2006 Share Posted November 21, 2006 Had a little problem this morning, wondering if someone might be able to help. As I was backing out of my driveway this morning, all of sudden I hear this clunking sound like I was dragging a pipe or something. I stop, get out, check the bottom....nothing. I get back in the car and let it roll under neutral and the sound is still there. I do this back n forth for about 5 minutes and it sounded like the noise was coming from the suspension area. As the wheels roll, the clunking begins. Then I back up for the last time and the sound was gone...I drove away and it never came back. WTH? What could it be? cold temperature? my low offset wheels? (38 on 17x7) TIA! Link to comment Share on other sites More sharing options...
UPSGuy Posted November 21, 2006 Share Posted November 21, 2006 I don't know if this will be of any help to you, but something like this happened to me as well. I was doing about 30, and heard a clunk that sounded like either something had dropped off the car and was dragging, or like I picked up a stick and was dragging it. I pulled over immediately and inspected both the underside of the car as well as the road that I had been driving on when it happened. No sign of anything. I got back in, drove away, and never heard it again. Link to comment Share on other sites More sharing options...
Nachowang Posted November 21, 2006 Author Share Posted November 21, 2006 UPSGuy, i'm 99% sure you and I are having the same problem. Are you running on stock rims? Link to comment Share on other sites More sharing options...
Legacy05 Posted November 21, 2006 Share Posted November 21, 2006 Have you guys checked your H-Brace to see if its tight? Link to comment Share on other sites More sharing options...
whitetiger Posted November 21, 2006 Share Posted November 21, 2006 best way yo diag this type of noise is to get a freind to drive the car while you listen from the outside. Link to comment Share on other sites More sharing options...
Nachowang Posted November 21, 2006 Author Share Posted November 21, 2006 Have you guys checked your H-Brace to see if its tight? Pardon my nOObiness, what's the H-brace? Link to comment Share on other sites More sharing options...
whitetiger Posted November 21, 2006 Share Posted November 21, 2006 its the metal brace under the transmission. Link to comment Share on other sites More sharing options...
UPSGuy Posted November 21, 2006 Share Posted November 21, 2006 I've never touched the H brace, but I'll check that out next time I'm under the car. My problem has since solved iteself though. Nachowang - does yours still sound like it's scraping? Link to comment Share on other sites More sharing options...
Nachowang Posted November 21, 2006 Author Share Posted November 21, 2006 I've never touched the H brace, but I'll check that out next time I'm under the car. My problem has since solved iteself though. Nachowang - does yours still sound like it's scraping? Nope, it went away after 5 minutes or so. I was rolling it back and forth and then it stopped. Link to comment Share on other sites More sharing options...
UPSGuy Posted November 21, 2006 Share Posted November 21, 2006 How very, very odd... I thought my problem was a one-off, so I was very surprised to see you post this! I'll post again when I've looked at the H brace. Link to comment Share on other sites More sharing options...
Legacy05 Posted November 21, 2006 Share Posted November 21, 2006 For me, the "Clunk" if you want to call it, happened when driving over speed bumps, or rolling up into the driveway ... Link to comment Share on other sites More sharing options...
AWDxBOOST Posted November 21, 2006 Share Posted November 21, 2006 I had the same proble...it was the h brace Link to comment Share on other sites More sharing options...
Nachowang Posted November 22, 2006 Author Share Posted November 22, 2006 Thanks Boost and everybody for your information. UPSGuy, if and when you check your H-brace, would you mind snapping a quick pic of it so we (mostly I) know if I have adjusted the right thing? I wonder if this would be in the vacation pix? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted November 22, 2006 Share Posted November 22, 2006 I had the same problem...it was the h brace Link to comment Share on other sites More sharing options...
UPSGuy Posted November 22, 2006 Share Posted November 22, 2006 Good to know AWDxBOOST. Thanks for the input. Nachowang, I'll snap that pic when I'm under the car, but I have to say, I don't know when the next time I'll be under it is... Link to comment Share on other sites More sharing options...
