DadSled Posted April 20, 2015 Share Posted April 20, 2015 I know Rodrigo & Juan they work on my car. They book for Mike Botti who flies down from up north to do Subie tunes once every month or two. For this next trip, he's already fully booked First thing though I want to go back to a catted downpipe. As per Cobb, their OTS tunes require catted. I want performance but above all I want the motor not to explode or quit Not sure but believe Rodrigo from WRXexperts in Miami does Accessport tunes . They tuned by brothers Subie and says they really did a great job with the tune. Link to comment Share on other sites More sharing options...
DadSled Posted April 22, 2015 Share Posted April 22, 2015 I went with e-tune..........Bren Tuning tuning paused, though, after 2 maps until leakdown test Friday and a new boost control unit tomorrow There is a Subaru specialist in riveria beach... a little bit north but absolutely will get the job done Link to comment Share on other sites More sharing options...
SPooky_leggy Posted April 25, 2015 Share Posted April 25, 2015 I went with e-tune..........Bren Tuning tuning paused, though, after 2 maps until leakdown test Friday and a new boost control unit tomorrow leet me know what are your results with brent tuning, because im tempted on going with an stage 2 e-tune from him on my spec b Link to comment Share on other sites More sharing options...
DadSled Posted April 27, 2015 Share Posted April 27, 2015 the first two maps Bren Tuning sent made a huge difference, was running better already but he paused tuning til I tracked down a mechanical issue. he was right. a hose from the intake had popped off and was leaking bad. also upgraded from OEM 2-port to Cobb 3-port boost solenoid so I'm kinda 'starting over' now, even though I've already seen significant improvements. so far so good leet me know what are your results with brent tuning, because im tempted on going with an stage 2 e-tune from him on my spec b Link to comment Share on other sites More sharing options...
DadSled Posted April 28, 2015 Share Posted April 28, 2015 I think Bren Tuning knows what they're doing, but I would only recommend an e-tune with anyone if your car has no CELs or mechanical issues which could affect the tune progress. Right now after 3 maps from Bren my car is still throwing a Fuel Bank 1 running lean CEL so tuner isn't reading any of my datalogs or sending any new maps. Meanwhile after 30 days, my e-tune 'contract' runs out The tuner says it's not his map, it's a mechanical issue. The local (very professional) Subie shop says the car checks out, it's probably the tune causing it. So I'm stuck in no man's land & it's starting to get aggravating the first two maps Bren Tuning sent made a huge difference, was running better already but he paused tuning til I tracked down a mechanical issue. he was right. a hose from the intake had popped off and was leaking bad. also upgraded from OEM 2-port to Cobb 3-port boost solenoid so I'm kinda 'starting over' now, even though I've already seen significant improvements. so far so good Link to comment Share on other sites More sharing options...
SoFloSubie Posted April 29, 2015 Share Posted April 29, 2015 I think Bren Tuning knows what they're doing, but I would only recommend an e-tune with anyone if your car has no CELs or mechanical issues which could affect the tune progress. Right now after 3 maps from Bren my car is still throwing a Fuel Bank 1 running lean CEL so tuner isn't reading any of my datalogs or sending any new maps. Meanwhile after 30 days, my e-tune 'contract' runs out The tuner says it's not his map, it's a mechanical issue. The local (very professional) Subie shop says the car checks out, it's probably the tune causing it. So I'm stuck in no man's land & it's starting to get aggravating Bring it to another specialist and get another opinion. Link to comment Share on other sites More sharing options...
SPooky_leggy Posted April 30, 2015 Share Posted April 30, 2015 I think Bren Tuning knows what they're doing, but I would only recommend an e-tune with anyone if your car has no CELs or mechanical issues which could affect the tune progress. Right now after 3 maps from Bren my car is still throwing a Fuel Bank 1 running lean CEL so tuner isn't reading any of my datalogs or sending any new maps. Meanwhile after 30 days, my e-tune 'contract' runs out The tuner says it's not his map, it's a mechanical issue. The local (very professional) Subie shop says the car checks out, it's probably the tune causing it. So I'm stuck in no man's land & it's starting to get aggravating and this is exactly what im afraid off, if any mechanical issue arises, then like u i could become stuck with no tune and loss of the money if i dont fix it in 30 days! Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 30, 2015 Share Posted April 30, 2015 Any of you Florida people work on Blount Island Marine Base? I arrived last night to get aboard the Sisler and noticed a dark grey 5th gen GT parked in one of the parking lots. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
DadSled Posted May 1, 2015 Share Posted May 1, 2015 (edited) All good. after we found a hose that popped loose, zip-tied it. installed new 3-port boost unit. reflashed to new map, reset ECU. still throwing same P0170 running lean for days. went back to shop, we immediately saw another hose / wastegate, had popped off. no ways we would both have missed that the first time. my guess is that it hap'd after we installed the 3-port. more boost? anyway we fixed that, reset ECU. idle is finally stabilized (since I bought the car, really...) CEL is gone, crazy amount of power and dare I say it the thing is almost too fast for my taste. it's way more speed than is even useable on the street, at least, in the crappy crowded boring roads of Miami... i think the car is officially bonkers now. sounds like chirping parakeets and goes like a rocket. just, no stickers rims bumpers flames etc three more datalogs today, finally moving on to next tune map... and this is exactly what im afraid off, if any mechanical issue arises, then like u i could become stuck with no tune and loss of the money if i dont fix it in 30 days! Edited May 1, 2015 by DadSled datalogs Link to comment Share on other sites More sharing options...
DadSled Posted May 1, 2015 Share Posted May 1, 2015 no ways man. where's that? my ride Any of you Florida people work on Blount Island Marine Base? I arrived last night to get aboard the Sisler and noticed a dark grey 5th gen GT parked in one of the parking lots. Link to comment Share on other sites More sharing options...
magnusonsubie Posted May 1, 2015 Share Posted May 1, 2015 no ways man. where's that? my ride It's in Jacksonville. Ship is here till the 7th and then we head to New Jersey to go into the ship yard. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
GotthatGT Posted May 1, 2015 Share Posted May 1, 2015 Way to OPSEC lol. Anyways, I'm new here and have a mod bug already. 2011 LGT Link to comment Share on other sites More sharing options...
SPooky_leggy Posted May 3, 2015 Share Posted May 3, 2015 It's in Jacksonville. Ship is here till the 7th and then we head to New Jersey to go into the ship yard. http://cdn.meme.am/instances/500x/56018129.jpg did u ever got that "death by powerpoint" OPSEC brief that said "not to post classified and unclassified information online?!(including FOUO) Link to comment Share on other sites More sharing options...
magnusonsubie Posted May 3, 2015 Share Posted May 3, 2015 Nope never got such a thing. So that meme is actually spot on. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
SPooky_leggy Posted May 3, 2015 Share Posted May 3, 2015 hahahahaha Link to comment Share on other sites More sharing options...
小灰灰 Posted May 9, 2015 Share Posted May 9, 2015 Anyone have vf40 for sale.? Good condition Link to comment Share on other sites More sharing options...
SPooky_leggy Posted May 22, 2015 Share Posted May 22, 2015 Anyone have vf40 for sale.? Good condition check the for sale page on the 05-09 gen,there's like 3 of em in around +/- $300 Link to comment Share on other sites More sharing options...
Adamn Posted July 1, 2015 Share Posted July 1, 2015 Figured I'd bump an old thread and say "Hi". In the Orlando/Oviedo area now. Just picked mine up last weekend from Jacksonville by way of GA. 2006 with 75k miles on it. Not bad. Link to comment Share on other sites More sharing options...
pakkuman Posted August 21, 2015 Share Posted August 21, 2015 Just picked up an 05 LGT here in Orlando, FL. Any meets in this area? Link to comment Share on other sites More sharing options...
DadSled Posted August 21, 2015 Share Posted August 21, 2015 Just picked up an 05 LGT here in Orlando, FL. Any meets in this area? I'd love to know, I'm driving a stage 2 OBP '05 LGT wagon in Miami, FL of all places Link to comment Share on other sites More sharing options...
peteyjr Posted August 22, 2015 Share Posted August 22, 2015 My twin brother Rod just picked up a cherry Red LGT Wagon . He's driving around in North Miami Beach area . Link to comment Share on other sites More sharing options...
Adamn Posted August 23, 2015 Share Posted August 23, 2015 I wish I had time for any meets in the Orlando area. It's been a long time since I was part of that scene ha ha. Too many kids now. Link to comment Share on other sites More sharing options...
DadSled Posted August 23, 2015 Share Posted August 23, 2015 My twin brother Rod just picked up a cherry Red LGT Wagon . He's driving around in North Miami Beach area . Have him PM me maybe Link to comment Share on other sites More sharing options...
peteyjr Posted August 23, 2015 Share Posted August 23, 2015 LGT's are a dying breed , whatever meets are out there are WRX/STI and probably now BRZ kids . It was like that even 5-6 years ago. Link to comment Share on other sites More sharing options...
GravityGear Posted August 26, 2015 Share Posted August 26, 2015 Hola. I just moved to NCFL, Gainesville. Would be nice to meet some of you guys! I know there's probably not much going on here with the subaru scene, but I'd be willing to drive out to Jax if there's more scene there. Link to comment Share on other sites More sharing options...
