Exhaust Leak!
washburn33
I had an AVO catback on Cobb DP. I have re-used gaskets and had no issue, but would normally recommend new ones (just gets expensive when you keep changing parts out like I seem to do).
Sounds to me like if you are hearing it up there, you need a second person to help. Shine a flashlight near the flanges (might need to turn the wheel and pull the fender liner) and rev the motor, while looking for a leak.
If it's the UP, it would be hard to hear at idle. Hop in the car, bring it up to about 3k in second gear and hit the gas. If it's the UP, you will know it...it's loud! UP leaks are easy to hear under boost. Also, I don't understand how installing a TB will cause an UP leak? If you're sure the sound is comming from the front of the car, check the manifold gaskets as well. I just replaced one of mine. Take the shielding off and look for soot.
you went from three cats to one (or none) and SS headers instead of cast iron. It's going to sound different. Mine does. The STi we did the same work on changed ALOT with just the Gruppe-S coated header.
well, that's good to know :lol: I'd say you have a leak! See post #7...you need help to track it down. Grab a flashlight and have someone rev the motor....or, look for carbon deposits. Should be evident after a few miles since the swap.
I've got the same. I have a slight leak around one bolt on the block, but everything's torqued down snug and other than a bit of carbon, it's good.
Perhaps the slipjoint? did you tighten it back up on install? The best way to find a look is carbon deposits.
