ECU reflash; CEL & P0457 trouble code?
I see references to Subaru blindly reflashing ECUs for customers with P0457 trouble codes, but what about vice-versa?
Can a reflash somehow result in a P0457 trouble code? (EEC leak / Fuel Cap)
I've got a story to tell, but I need a couple days to check some facts first!
Thanks.
My P0457 (or at least that's what I think it was) came on when I had the car on ramps while doing an oil change. The fuel tank was full (<3 miles before) and it came on within a few seconds of starting the car. Scared the crap out of me... but went away when I pulled the car off the ramps, and then restarted it.
It came up in a google search -- perhaps on NASIOC.
The post referenced a Subaru TSB (if I recall correctly) from the New Jersey region which listed three error codes which should result in an automatic reflash; P0457 was one of them.
The gist of the thread was along the lines of, "If you want a free reflash/update, unscrew your fuel cap."
That was an email from SNE to its dealers in 2001 about the availability of an SOA reflash for the 2002 WRX which fixed a spurious P0457 problem. Zero applicability to your car. You've got a "gross" evaporative emissions leak. Your gas cap might be cross-threaded or defective, a hose might be loose, or a fuel tank gasket is crimped.
