darren94 Posted September 2, 2006 Share Posted September 2, 2006 will 17x7 5x100 with a 40mm offest fit a stock lgt 2005?? Link to comment Share on other sites More sharing options...
Xenonk Posted September 3, 2006 Share Posted September 3, 2006 did you read the FAQ? yes, they fit Keefe Link to comment Share on other sites More sharing options...
Scooter Posted September 3, 2006 Share Posted September 3, 2006 ^^ Keefe is The Oracle. The 40mm offset means that the new wheels will stick out 15mm further outboard than the stock wheels at each corner. Keefe's sticky shows ET37 as the limit for a 7" wide wheel, so you are pretty close to the limit, but doable. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
darren94 Posted September 3, 2006 Author Share Posted September 3, 2006 thanks guys. i think i am gonna go with a 17x7 with a 48 offset. If my understanding is correct, the wheels will look more like stock(i.e not sticking out and rubbing fenders)? Link to comment Share on other sites More sharing options...
Xenonk Posted September 4, 2006 Share Posted September 4, 2006 ^ correct. You got it. Most wheels will have a lower offset than stock (unless you got some CUSTOM wheels). Keefe Link to comment Share on other sites More sharing options...
