rougeben83 Posted August 28, 2006 Share Posted August 28, 2006 Does anyone have a good spring rate setup for the Ksports? My application would be daily driving (Detroit AND New York City...double whamy on the bad roads?), with a little bit of autocross and rallycross thrown in. I was thinking of 6kg fr/ 6kg rear with the stock 19mm fsb and 22mm rsb. The reason for the lower spring rate in the rear is because in autocross I found the 22mm rsb to be just right in getting the car to rotate in tight corners with the stock springs. I don't want to significantly increase oversteer on the car. Would a 6kg f/7kg r be a better choice (following the original spec of 7f/9r). Thanks! Link to comment Share on other sites More sharing options...
Th3Franz Posted August 29, 2006 Share Posted August 29, 2006 you want a stiffer rear spring rate by at least 1 kg/mm. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
rougeben83 Posted August 29, 2006 Author Share Posted August 29, 2006 6f/7r then? or 6f/8r? Link to comment Share on other sites More sharing options...
