Tim_in_MD Posted August 21, 2006 Share Posted August 21, 2006 We've noticed on our '06 OBW that the driver's door is slightly misaligned--it's about 1/4" lower than the rear door on that side, as judged by the lower trim, the body cut line and the weatherstripping. It seems to fit against the weatherstripping well enough, but it's just lower than it should be. The panel gaps look OK. The door makes a two-stage sound (KLUNK-klunk) when it closes, which makes me think the latch is hitting twice because of this misalignment. The other doors all shut with one "klunk". Anybody else have this issue, or know if there's an adjustment that can be done? Link to comment Share on other sites More sharing options...
captainmorgan Posted August 21, 2006 Share Posted August 21, 2006 mine droops a little bit too. just enough to catch the edge of the body molding around the rear wheel well when its hot out. I'm thinking about going to a body shop to have all the doors realigned Link to comment Share on other sites More sharing options...
red beast Posted August 21, 2006 Share Posted August 21, 2006 my driver, rear, lower, sill edge is in too much causing the paint to be pitted on the door jamb. Link to comment Share on other sites More sharing options...
rabydanimal Posted August 22, 2006 Share Posted August 22, 2006 From what I've read this is inevitable on all Subarus, but on an '06? I'd have the dealer look at it. Link to comment Share on other sites More sharing options...
