onesillyracer Posted August 19, 2006 Share Posted August 19, 2006 So yesterday I picked up my 05 lgt from the dealership and ran in out to do errands with the car. at one point i noticed when the car isnt moving and you turn the steering wheel from side to side, i hear a knocking type sound, yet when i am in motion i do not hear it. is this something to worry about? the car has 20k miles and is lowered on swift racing springs. Link to comment Share on other sites More sharing options...
onesillyracer Posted August 20, 2006 Author Share Posted August 20, 2006 anyone? Link to comment Share on other sites More sharing options...
mccorry Posted August 20, 2006 Share Posted August 20, 2006 Sounds like a tie rod end to me...... Link to comment Share on other sites More sharing options...
onesillyracer Posted August 20, 2006 Author Share Posted August 20, 2006 Tie rod end? the sound is quite noticeable when not in motion and turning the wheel from side to side, you hear like a metal clunking kind of sound. would this be covered under warranty? Link to comment Share on other sites More sharing options...
TravisS Posted August 20, 2006 Share Posted August 20, 2006 There was somebody else who noticed this and posted a thread about it a while ago. I can't seem to find the thread... and I was trying to find it because it had good info on why this happens. But basically, it's normal (when you're stopped). Link to comment Share on other sites More sharing options...
onesillyracer Posted August 21, 2006 Author Share Posted August 21, 2006 damn, wish you could find that thread! Link to comment Share on other sites More sharing options...
whitetiger Posted August 21, 2006 Share Posted August 21, 2006 if the steering is knocking, then open the door and let it in..... steering knock is mostly due to a worn tie rod or ball joint in more severe cases. Could be too much play in the steering rack, but that almost never happens. If its happening while the car is still, have a friend make the noise while you listen around the car to see if you can pin down where its comming from. You should be able to determine at least what side its on. Link to comment Share on other sites More sharing options...
onesillyracer Posted August 21, 2006 Author Share Posted August 21, 2006 the sound appears to be coming towards the drivers side. i happened to bump the thread in the warranty forums. looks like this problem is really common with the legacys. Link to comment Share on other sites More sharing options...
whitetiger Posted August 21, 2006 Share Posted August 21, 2006 if you are brave enough. stick you hand under the car and hold on to different joints and links while someone is turning the wheel. you should be able to feel the knocking from the part that is causing it. Link to comment Share on other sites More sharing options...
OBXTbyrequest Posted April 5, 2014 Share Posted April 5, 2014 Bumping an old thread about bumping. Any resolution to this? I suspect I'm having a tie rod / LCA / CV Axle / ball joint issue as well, but the symptom is very similar to what you've described. I'm also getting a rubbing type noise when my suspension reaches full extension (front is raised slightly after a bump). Haven't had a chance to lift it up and look, or test this out with someone else yet so who knows. Link to comment Share on other sites More sharing options...
