iuksob03 Posted August 16, 2006 Share Posted August 16, 2006 Had a friend tell me he's been wetting down the front of his car and using dryer sheets to pull the bugs off the bumper. Is this safe? I'm leaning towards no just because of the texture of the sheet rubbing against the paint. Link to comment Share on other sites More sharing options...
bosco Posted August 16, 2006 Share Posted August 16, 2006 whats the front of his car look like? bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 16, 2006 Share Posted August 16, 2006 Spray some WD40 on there and let it soak- makes things much easier- and if you're gonna be driving through a buggy area, spray the front of the car (NOT the windshield) with WD40 and things will be easier. Link to comment Share on other sites More sharing options...
iuksob03 Posted August 16, 2006 Author Share Posted August 16, 2006 whats the front of his car look like? bosco It's a new pontiac g6, but haven't had a chance to see it with any of the bugs on it. Link to comment Share on other sites More sharing options...
bosco Posted August 16, 2006 Share Posted August 16, 2006 Spray some WD40 on there and let it soak- makes things much easier- and if you're gonna be driving through a buggy area, spray the front of the car (NOT the windshield) with WD40 and things will be easier. isn't there a solvent in WD-40? i know if you take a sticker off of something the WD-40 really works good on the glue residue to remove it. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 16, 2006 Share Posted August 16, 2006 Yup- don't spray it on your stickers. Link to comment Share on other sites More sharing options...
bosco Posted August 16, 2006 Share Posted August 16, 2006 Yup- don't spray it on your stickers. master i am awed by your knowledge of things. thank you. bosco:lol: Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
itzed Posted August 16, 2006 Share Posted August 16, 2006 Jedi, do you advocate the use of anal lube to keep the back bumper free of dirt and road grime thrown up in the rain? and a very thin layer of KY Jelly on the front.... Link to comment Share on other sites More sharing options...
ilh Posted August 16, 2006 Share Posted August 16, 2006 I use clay on the few bugs I can't get off with (car wash) soap. It takes them right off. Link to comment Share on other sites More sharing options...
PGT Posted August 16, 2006 Share Posted August 16, 2006 dryer sheets are used to keep live bugs away. Like.....stick it in the stroller with your toddler to keep mosquitos away without having to use a strong bug spray which might be bad for the kid. Dryer sheet to remove dead bugs?? someone got their 'Hints From Heloise' mixed up. Link to comment Share on other sites More sharing options...
Spec B Posted August 16, 2006 Share Posted August 16, 2006 They also work as racing air filters...at least the snuggle ones do. Link to comment Share on other sites More sharing options...
jerami1981 Posted August 16, 2006 Share Posted August 16, 2006 ^ you lie, i just tried it and my engine sucked that sucker right into the damn engine..now what do i do...cel is p0983 low laundry detergent.. Link to comment Share on other sites More sharing options...
twisted Posted August 16, 2006 Share Posted August 16, 2006 dont forget to insert the 4 quarters in the gas tank Link to comment Share on other sites More sharing options...
Spec B Posted August 16, 2006 Share Posted August 16, 2006 dont forget to insert the 4 quarters in the gas tank. :lol: so seriously...do they help remove bugs?? Link to comment Share on other sites More sharing options...
iuksob03 Posted August 16, 2006 Author Share Posted August 16, 2006 kid said he saw it on the g6 forums, so it must be gospel G6 Performance Forum :: View topic - bug removal system Link to comment Share on other sites More sharing options...
blackheart Posted August 16, 2006 Share Posted August 16, 2006 I've done it on my fiberglass motorhome. It does work, but it's still a lot of rubbing. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 16, 2006 Share Posted August 16, 2006 Jedi, do you advocate the use of anal lube to keep the back bumper free of dirt and road grime thrown up in the rain? I advocate the use of anal lube with anything at any time- it never hurts. Helps prevent pink sock syndrome too, or so I hear Link to comment Share on other sites More sharing options...
OCDetails Posted August 17, 2006 Share Posted August 17, 2006 Is this guy living in some amish colony or something? I'm all for home remedies, but c'mon... just get some bug remover or use the mesh backing on a wash mitt to scrub bugs off. No need to get exotic by using a dryer sheet. IMO that is a little more coarse than what I would rub on my car, but that's just me. Use a little Eagle One Bucketless Wash to presoak the bugs and they'll wash right off with maybe a little extra elbow grease. A better solution would be to not let them sit on your bumper so long that you have to find a mild enough grit sand paper to get them off with. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
pillboy Posted August 17, 2006 Share Posted August 17, 2006 it never hurts That would be because of the lube. It is still ugly. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 17, 2006 Share Posted August 17, 2006 That would be because of the lube. Droll- I'll bet some others don't get it. Link to comment Share on other sites More sharing options...
bosco Posted August 17, 2006 Share Posted August 17, 2006 take wet towels and cover the offending area, keep them wet, remove towels in about 30 min. (could take longer depending on bug concentration), wash as normal bugs should be easy to remove. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
subie_dude05 Posted August 29, 2006 Share Posted August 29, 2006 i have used some horrible stuff in past years, but something i found to work and havent been able to find since i ran out is a bug and tar remover made by GUNK. the company who makes the engine degreaser...etc. it had to presoak and then wiped off with a wet rag before you wash the car but it did a great job. Link to comment Share on other sites More sharing options...
schwinn Posted August 31, 2006 Share Posted August 31, 2006 I recently used TurtleWax Bug and Tar remover. Goes on like a creamy solution, and really took the tar marks off the car. They say it leaves a "protective coating" or some such, but I don't buy that part... at least it took the tar off VERY easily. Link to comment Share on other sites More sharing options...
