Mines Posted August 11, 2006 Share Posted August 11, 2006 Hey Guys I have an H7 HID kit that my cousing just gave me. I want to change my bulbs to genuine philips D2S bulbs. I was wondering if I could keep the same ballast? and if I could keep it, what modifictations i would need to make to the projecter and what additional harnesses would I need to make this work. Also, I was looking around on xenondepot and I found this. 4300k XenonDepot Philips Replacement Bulb XD-4k-RB I was wondering if these bulbs are genuine philips d2s bulbs modified to fit the h7 housing or these are something else. thanks guys Link to comment Share on other sites More sharing options...
PGT Posted August 11, 2006 Share Posted August 11, 2006 PIAA makes some DS2 bulbs Link to comment Share on other sites More sharing options...
VXCL Posted August 11, 2006 Share Posted August 11, 2006 you dont need to modify the projector. it more of an issue of getting the bulb to secure becuase the oem h7 lock wont work. h7 and d2s have the same focal point. also to use your old kit ballasts you will not have d2s connectors to power the bulbs. you can buy the connectors but at that point might as well just drop $150-$200 on a set of oem d2s ballasts with philips d2s bulbs on ebay. i would sell you a set myself but i need it for someone's retro. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
power_getter Posted August 12, 2006 Share Posted August 12, 2006 You get H7 to D2S adapter from hidplanet.com Link to comment Share on other sites More sharing options...
VXCL Posted August 15, 2006 Share Posted August 15, 2006 You get H7 to D2S adapter from hidplanet.com those def help center the bulb and get it positioned close, but the d2s is so wide you still cant get the oem h7 lock over the d2s base, and even if you did the oem h7 lock then interferes with the power connectors. i had zero luck with that. i figured b4 i do my full xenon d2s projector retro i would mess with the d2s in our projectors to help other members go that route. saw it as a complete waste of time and projector retro was easier for me and better results. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 16, 2006 Share Posted August 16, 2006 those def help center the bulb and get it positioned close, but the d2s is so wide you still cant get the oem h7 lock over the d2s base, and even if you did the oem h7 lock then interferes with the power connectors. i had zero luck with that. i figured b4 i do my full xenon d2s projector retro i would mess with the d2s in our projectors to help other members go that route. saw it as a complete waste of time and projector retro was easier for me and better results. I have D2S bulbs in my OEM projector and while the bulb base is a bit wider, I got the locks to fit over them only a little bending. Took about 10 seconds. There is also no interference with the power connectors. Everything just dropped in. The only thing I added were a set of centering rings to position the D2S bulbs in the H7 housings. I've been running my custom HID setup for at least a year and half with no issues whatsoever. Link to comment Share on other sites More sharing options...
VXCL Posted August 16, 2006 Share Posted August 16, 2006 I have D2S bulbs in my OEM projector and while the bulb base is a bit wider, I got the locks to fit over them only a little bending. Took about 10 seconds. There is also no interference with the power connectors. Everything just dropped in. The only thing I added were a set of centering rings to position the D2S bulbs in the H7 housings. I've been running my custom HID setup for at least a year and half with no issues whatsoever. what ballasts are you using. i only had one pair at the time and the connectors were a problem so i said screw it early on. they were gen 3 hella ballasts out of a 02 audi a6 with the red power connectors. kioto (toyota and lexus) ballasts use much much smaller connectors. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 16, 2006 Share Posted August 16, 2006 what ballasts are you using. i only had one pair at the time and the connectors were a problem so i said screw it early on. they were gen 3 hella ballasts out of a 02 audi a6 with the red power connectors. kioto (toyota and lexus) ballasts use much much smaller connectors. Matsushita Link to comment Share on other sites More sharing options...
VXCL Posted August 17, 2006 Share Posted August 17, 2006 Matsushita those are smaller then the hella gen 3 but a little bigger then the kiotos. you should post up a pic of your d2s locked in place. would help alot of members who would like to go the same route and not by a stupid inferior kit. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 23, 2006 Share Posted August 23, 2006 those are smaller then the hella gen 3 but a little bigger then the kiotos. you should post up a pic of your d2s locked in place. would help alot of members who would like to go the same route and not by a stupid inferior kit. Sorry, didn't see your request till now. Here are the pics from when I install the HID's a while ago: http://i6.photobucket.com/albums/y207/Pisadong/109-0954_IMG.jpg http://i6.photobucket.com/albums/y207/Pisadong/109-0952_IMG.jpg http://i6.photobucket.com/albums/y207/Pisadong/109-0966_IMG.jpg Link to comment Share on other sites More sharing options...
VXCL Posted August 31, 2006 Share Posted August 31, 2006 cool thanks. i just added you to my retro list in from my retro post in my sig MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
