Are there Down Pipes with a Cat and 3" Outlet?
svx6
So I did a search here and it seems like all of the downpipes taper back down to 2.5 inches to mate to the stock exhaust system. Are there any around that have a 3" outlet...I was thinking about going 3" piping custom piping from turbo to the tailpipes. Would I be better off just getting one of the downs that has a 2.5" outlet and having it cut, and then having a 2.5" adapter handy if I ever decided to go back to stock exhaust system? Gets confusing after a while...
thanks in advance,
Syd
The non-existent and never to be produced Helix downpipe was to have such specs. Because it was rumored to have such a great price I was waiting for it. I will probably go with the Autospeed downpipe, as it does exist and is at least reasonable in price. Lachute describes having both a 2.5 inch and 3 inch flange, but I cannot find on their website the actual pipe dimensions, also a little pricey, even factoring a Canadian conversion. Perrin does have a catless 3" FTW or FTL, depending on your point of view. I'm not sure about the AVO specs, but if you've got the money . . .
Just trying to boost my post count. I believe I'm the most senior "new member" by a longshot.
PDE has a full 3" outlet, with a 2.5" reducer welded in to mate with the stock catback. You can remove this reducer and you will have a full 3" flat flange to connect to real full length 3" catbacks.
Actually, mine will be for sale shortly as it wont work with the direction I will be going with the car in the near future ;).
Most of the WRX units are 3". APS makes a 3" or 3.5" with optional HFC insert. If you going custom catback, then any WRX/STi DP should work fine. I'm using my old Turbo XS 4"DP (3" outlet) with a turbo XS 3" HFC and 3" custom piping to the tailpipes (http://legacygt.com/forums/intake-exhaust/40436-my-stealth-dual-exhaust.html). Works fine! I kept the stock system so I can change back at any time.
Here is an explanation from PDE. Not that I agree or understand...
I think it means that you need some kind of expansion joint here and that a custom joint isn't worth the HP gains.
PDE :: CREATIVITY | PERFORMANCE | VALUE
You dont need any thing fancy. Basically the pipe is 3" all of the way, and at the flange, it has a reducer welded in with a spot for the donut gasket to sit. When you want to use it with a full 3" catback, just cut the reducer out.
I think the AVO has a 3" tubing the whole way with a 2.5" opening (don't think there's a slip fit). However given the price and the cat location you're probably better off elsewhere. If I have problems in 5 years with CA emissions I'll consider it.
I think the Lachute pieces are made to order.
