bbeast Posted August 7, 2006 Share Posted August 7, 2006 How bad is it if you put to much oil in your engine? I checked my oil the other day on a cold engine and the level was just below the L. So I topped it off with a quart of oil. This brought the level up to the notch on the dipstick (which is above the Full line). I checked the maual and it said on a cold engine to be sure to only fill up the oil resevoir to the F and not above. The notch is there to allow for thermal expansion (the Full Line on a hot engine). Hmmm..... Link to comment Share on other sites More sharing options...
deneb Posted August 7, 2006 Share Posted August 7, 2006 I don't think it's anything to worry about, you're probaly not even 1/2 quart too full. In my experience, 1/4 qt. took me from midway between the L and F dots to the F dot, but others have said the distance between the L dot and F dot is 1 qt. Either way, you should be OK. And if your LGT is using oil, you'll be back to the F dot in a few hundred to a few thousand miles anyways. Link to comment Share on other sites More sharing options...
bbeast Posted August 7, 2006 Author Share Posted August 7, 2006 Well, it seems my LGT is using about a quart every 1000 miles, but I have to do more testing to verify. I am using AMSOIL synthetic..... Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 7, 2006 Share Posted August 7, 2006 I'm pretty sure that's well within the tolerance band. The only time you have to worry is if you have A LOT of extra oil in there... Like 2 quarts extra. If that happens, then it may be possible for the crank to froth up the oil. This could lead to oil starvation. I don't know what the Subaru tolerance is, but I'm fairly sure that modern engines can accommodate at least 1/2 quart extra with no problem. Link to comment Share on other sites More sharing options...
ElCoyote Posted August 8, 2006 Share Posted August 8, 2006 I'm pretty sure that's well within the tolerance band. The only time you have to worry is if you have A LOT of extra oil in there... Like 2 quarts extra. If that happens, then it may be possible for the crank to froth up the oil. This could lead to oil starvation. "It will pressurize the sump and blow seals" like an Eskimo couldn't I don't know what the Subaru tolerance is, but I'm fairly sure that modern engines can accommodate at least 1/2 quart extra with no problem. Link to comment Share on other sites More sharing options...
j255c Posted August 9, 2006 Share Posted August 9, 2006 yeah i checked my oil no a cold engine and didn't see anything on my dipstick. Filled it up w/ 2 quarts now its like a half inch passed the full line.. should i drain a little out? 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
LongHiway Posted August 9, 2006 Share Posted August 9, 2006 I think you are OK as well but, draining some oil will let you sleep better. Link to comment Share on other sites More sharing options...
