funkpelts Posted August 1, 2006 Share Posted August 1, 2006 My new LGT has a door handle that is kinda iffy. Has anyone else had this problem and is it worth having my dealer dink with it? Link to comment Share on other sites More sharing options...
MilesA Posted August 1, 2006 Share Posted August 1, 2006 What do you mean by "iffy"? And which door handle are you referring to: inside or outside? Link to comment Share on other sites More sharing options...
Scooter Posted August 1, 2006 Share Posted August 1, 2006 And which door handle are you referring to: inside or outside? +1..? If it's the inside handle, then yeah, I probably had the same problem. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
funkpelts Posted August 2, 2006 Author Share Posted August 2, 2006 Inside the door. Everything looks fine, but sometimes when you try to open the door the handle gives a little bit of resistance. I don't know how good my local dealer will be at fixing this. It's only maybe 1 out of 5 tries that this happens, but the door handle itself doesn't seem like it is built very well, and I don't know if it could break sometime. What do you mean by "iffy"? And which door handle are you referring to: inside or outside? Link to comment Share on other sites More sharing options...
Scooter Posted August 3, 2006 Share Posted August 3, 2006 Hmmm. That's not actually the problem I had, after all. Mine was a fit issue with the big fixed 'grab handle' on the door panel, not the actual release mechanism. My grab handle never fit right at the top and after replacing that handle twice and having it break again, I encouraged my dealer to replace the whole door trim panel, which they did. Yours sounds like something you should definitely take in and complain about, but it also sounds like one of those types of things the dealerships aren't very good at fixing. Or acknowledging. If you can show them that the mechanism feels different than the other doors they should be willing to address it for you. Good luck! Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
RacingFish Posted August 3, 2006 Share Posted August 3, 2006 mine is loose.. and i work for subaru.... it doesnt feel as secure... Link to comment Share on other sites More sharing options...
rallispec Posted August 3, 2006 Share Posted August 3, 2006 my passenger door handles sticks once in a while..... i'll pull up on it and think that the door is still locked, until i realized that i just have to pull a bit harder and it pops open. Link to comment Share on other sites More sharing options...
crossdog Posted August 4, 2006 Share Posted August 4, 2006 Inside the door. Everything looks fine, but sometimes when you try to open the door the handle gives a little bit of resistance. I don't know how good my local dealer will be at fixing this. It's only maybe 1 out of 5 tries that this happens, but the door handle itself doesn't seem like it is built very well, and I don't know if it could break sometime. Same problem. Does not happen every time. I keep waiting for the day that I go to open the door and it breaks the mechanism. I do not think the dealer can fix b/c it is hard to re-create the problem. Link to comment Share on other sites More sharing options...
MrCoffee Posted August 4, 2006 Share Posted August 4, 2006 Same problem here. Dealership said it would be a pain to fix and on my dollar since it's not causing problems. Link to comment Share on other sites More sharing options...
