LittleBlueGT Posted July 31, 2006 Share Posted July 31, 2006 I will be getting my TBE exhaust shortly (w/ HFC) and my local parts coater (he did my headers) said it would not be a problem to coat the DP, even though it has a cat. He said he would coat the outside like normal, and then use rags to protect the cat while he did the first part of the inside. What do you guys think? Possible? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Th3Franz Posted July 31, 2006 Share Posted July 31, 2006 The rags would hold up to the massive heat ceramic coating entails? Uh.. normally I have heard it doesn't work well to coat any exhaust piece on the inside with a cat in it. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
bugblatterbeast Posted July 31, 2006 Share Posted July 31, 2006 I think it is possible. The rags wouldn't have to take the full curing temperature. You can get a partial cure at lower temperature, remove the rags then crank the heat up. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 31, 2006 Author Share Posted July 31, 2006 I think it is possible. The rags wouldn't have to take the full curing temperature. You can get a partial cure at lower temperature, remove the rags then crank the heat up. I think that is what he plans to do. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
wukindada Posted July 31, 2006 Share Posted July 31, 2006 Not worth the chance in my opinion.... I'd just get the outside coated, then wrap it.... Hmmmmmm.....thats exactly what I'm doing:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
legacy_y_tu Posted July 31, 2006 Share Posted July 31, 2006 Why don't you do what I'm planning on doing. 1. Cut the HFC off. 2. Get coated 3. Weld HFC back on 4. Enjoy Link to comment Share on other sites More sharing options...
rc0032 Posted August 1, 2006 Share Posted August 1, 2006 Moved to pipes Why coat it Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 1, 2006 Author Share Posted August 1, 2006 Moved to pipes Why coat it Didn't even notice their was another section. Only the top part of the DP can benefit from coating, it helps keep engine bay temps cooler, adn results in less heat going to the TMIC. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
rc0032 Posted August 1, 2006 Share Posted August 1, 2006 Only the top part of the DP can benefit from coating Then why not just coat the top part and not the whole pipe. Issue solved. Link to comment Share on other sites More sharing options...
wukindada Posted August 1, 2006 Share Posted August 1, 2006 Really only the top half need's to be coated..... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 1, 2006 Author Share Posted August 1, 2006 Then why not just coat the top part and not the whole pipe. Issue solved. The piece has to put in an oven to bake it, can't really put in just half of a pipe. FWIW I will also be getting the heat-shield coated to further help. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
legacy_y_tu Posted August 1, 2006 Share Posted August 1, 2006 The piece has to put in an oven to bake it, can't really put in just half of a pipe. You can if you do what I suggested . Link to comment Share on other sites More sharing options...
Waxiboy Posted August 1, 2006 Share Posted August 1, 2006 ^ that is what peterjmc did. coated by Crucial I think. My catted DP is being coated now at Thermaltech Link to comment Share on other sites More sharing options...
Deer Killer Posted August 1, 2006 Share Posted August 1, 2006 Moved to pipes Why coat it Did you notice all the heatshields on the stock equipment? Did you think they were a bad thing? Link to comment Share on other sites More sharing options...
praedet Posted August 1, 2006 Share Posted August 1, 2006 Get the top cut-off and flanges welded on... Send off to coating Bolt it back together when it is ready Ted Link to comment Share on other sites More sharing options...
specinvstr Posted August 1, 2006 Share Posted August 1, 2006 Hmmm, I might have to get this done. Time to PM crucial.... Link to comment Share on other sites More sharing options...
Steiner Posted August 2, 2006 Share Posted August 2, 2006 Is inside coating as important after the turbo as it is before the turbo for performance? I'd think not since I thought the exhaust velocity was most important getting to the turbo but every little bit probably helps. For underhood heat control, I think everything helps. My plan is getting my catted dp outside coated, equal-length headers/up inside/outside coated, turbo heatshield coated, and give the turbo the Crucial port/polish/coat/dissipant treatment. My car puts off a magnificent amount of heat at a standstill. Just the other day I parked it after a drive and an hour later was still able to toss a couple of salmon fillets on the intercooler for dinner. Worked great. The fish doesn't flake off and fall down between the fins as easy as on the grill when you flip it. Experience is something you don't get until right after you needed it. Link to comment Share on other sites More sharing options...
