tigersan Posted July 31, 2006 Share Posted July 31, 2006 ok, recently(about 50 miles ago) i put my old tires and wheels on my brand new LGT the tires were visibly worn to different levels, as I was unaware of the AWD same tire wear fact I fear I may have damaged my car. Recently I have noticed Increased noise, sounds similar to raod noise but mor e of a howling. Should I keep driving this way until it breaks them swap back and let waranty eadl with it, or should I switch back asap and see if noise dissapears? thanks Link to comment Share on other sites More sharing options...
LawGT Posted July 31, 2006 Share Posted July 31, 2006 "Should I keep driving this way until it breaks them swap back and let waranty eadl with it, or should I switch back asap and see if noise dissapears?" I'm sorry, but that just sounds stupid. Remove the old worn tires ASAP and replace with new ones. Link to comment Share on other sites More sharing options...
tigersan Posted July 31, 2006 Author Share Posted July 31, 2006 I agree it may sound stupid, but if the damage is done I want to make sure it runs its course before the warranty is up. Link to comment Share on other sites More sharing options...
sgt Posted July 31, 2006 Share Posted July 31, 2006 The howling is most likely road noise. The tires are probably worn unevenly. If you cant take the noise change them. Link to comment Share on other sites More sharing options...
