zuczek Posted July 30, 2006 Share Posted July 30, 2006 Hello, I was wondering if there is a way to change the HVAC display from Farenheit to Celcius? I don't have the car yet but I'm wondering if it's a simple process or the display needs to be changed. Thanks Link to comment Share on other sites More sharing options...
scottmcphee Posted August 1, 2006 Share Posted August 1, 2006 Hello, I was wondering if there is a way to change the HVAC display from Farenheit to Celcius? I don't have the car yet but I'm wondering if it's a simple process or the display needs to be changed. Thanks Buy the car in Canada! It comes that way Link to comment Share on other sites More sharing options...
zuczek Posted August 1, 2006 Author Share Posted August 1, 2006 I am in Canada. Link to comment Share on other sites More sharing options...
Boulderguy Posted August 1, 2006 Share Posted August 1, 2006 Yes, all you have to do is convert the clock from SAE to metric, everything else switches to metric once you're on metric time. Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted August 2, 2006 Share Posted August 2, 2006 Unfortunately...it's not a matter of switching a switch. It's a matter of purchasing another (metric spec) display unit. Sigh...two part numbers instead of a dual-purpose display; such a waste. Link to comment Share on other sites More sharing options...
leftride Posted August 2, 2006 Share Posted August 2, 2006 if you are in canada i dont see the issue are you importing an american car? *vb gallery* Link to comment Share on other sites More sharing options...
pillboy Posted August 2, 2006 Share Posted August 2, 2006 I want mine to read in Kelvin. It is still ugly. Link to comment Share on other sites More sharing options...
Scooter Posted August 2, 2006 Share Posted August 2, 2006 Gotta be a 'secret code' for this, like the seatbelt chime disable, right? It would be silly to have to purchase a different display unit... Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Jon in CT Posted August 2, 2006 Share Posted August 2, 2006 if you are in canada i dont see the issue are you importing an american car?Duh! heh! You seem to be a good candidate for the the 2007->2005 headunit swap. Not only do you get the AUX-IN, but you get temperature in SI units! Link to comment Share on other sites More sharing options...
fzanetti Posted August 2, 2006 Share Posted August 2, 2006 Unfortunately...it's not a matter of switching a switch. It's a matter of purchasing another (metric spec) display unit. Sigh...two part numbers instead of a dual-purpose display; such a waste. Exactly!!! Sucks.... Even GM's, Fords, they all allow you to change to Metric x US anytime.... Another shame on you SoA!!! Flavio Zanetti Boston, MA Link to comment Share on other sites More sharing options...
Gire Posted August 2, 2006 Share Posted August 2, 2006 I'd love to get my metric Canadian car to read out in MPG instead of the lame-o "11.2 litres/100 KM's" style of economy measurements that we all are forced to use up here... Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2006 Share Posted August 2, 2006 I'd love to get my metric Canadian car to read out in MPG instead of the lame-o "11.2 litres/100 KM's" style of economy measurements that we all are forced to use up here... Wanna swap? I will happily swap to not read those lame MPG... Also... if anyone knows how to swap the headunit to read in C instead of F. Link to comment Share on other sites More sharing options...
Boulderguy Posted August 2, 2006 Share Posted August 2, 2006 I'd be up for switching to metric, makes so much more sense than the other. Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted August 2, 2006 Share Posted August 2, 2006 If the price were....well, Semi-reasonable, I'd be up for having one of each; Metric and Standard. Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2006 Share Posted August 2, 2006 So it's clear that the trip carputer can't be switched, because the display is different. But I find it hard to believe that stereo/ACC unit cannot be switched. I guess I need to remove it from the car and look for some switch or jumper. Can anyone from Canada find the part # for the headunit? I need to search the forum maybe there is the part # for USDM one. If not it should be on the headunit itself, or a dealer should be able to tell. I really don't get it... Subaru decides to put the same engine block in multiple cars (Legacy, WRX, STI, Forrester) to share parts, but would come up with different part # for stereo or trip carputer. Link to comment Share on other sites More sharing options...
zuczek Posted August 3, 2006 Author Share Posted August 3, 2006 I wonder if something were to "break" on the head unit and I took it to a dealer in Canada, would they install the metric unit instead? Link to comment Share on other sites More sharing options...
