hal9e3 Posted July 30, 2006 Share Posted July 30, 2006 So, I was futzing around with my hybrid TBE today - Cobb catted DP, Lachute res/Y and stock cans - when I noticed that the chromed exhaust tip covers are attached with two bolts. I like this setup pretty well except for the bling factor, so it occurred to me: hey, all I need is some nicer tips, maybe paint the cans black, and I'd be in bidnezz. Anybody know of a company that sells tips only? Magnaflow maybe? BTW the tip sans cover looks, well, interesting: Link to comment Share on other sites More sharing options...
coolbluelb Posted July 30, 2006 Share Posted July 30, 2006 Are the tips moveable to accomodate both sedan and wagon applications? Link to comment Share on other sites More sharing options...
hal9e3 Posted July 30, 2006 Author Share Posted July 30, 2006 Stock or aftermarket? The stock tips can't be easily moved but the covers could be shifted backwards or forwards a little bit by enlarging the bolt hole. Magnaflow does sell tips separately but looks like they need to be welded on. Sent them an email to confirm. If they can be attached with bolts then some adjustment should be possible. If they need to be welded then you can custom fit the length by where you cut off the old tips. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 2, 2006 Author Share Posted August 2, 2006 Looked into this a little more. Magnaflow and Borla, just to name a couple, sell stainless steel tips. The Magnaflow tips are all 2.25" diameter inlet, while the Borlas are either 2.25" or 2.5". They both come in a variety of shapes, sizes and lengths. The stock muffler tip starts at ~2" in diameter, flares to ~2.4" in diameter and then flattens out into a rounded rectangle shape. Magnaflows have to be welded on, while some of the Borlas come with a clamp. Not sure whether the 2.5" Borla would be compatible. Can you say coke can shim? Link to comment Share on other sites More sharing options...
TSiWRX Posted August 2, 2006 Share Posted August 2, 2006 Surf the Summit Racing and JC Whitney catalogs - lots of stuff. Also check eBay. There's actually some decent-quality tips there - mostly weld-on applications for various "modern American muscle." You should be able to "adapt" some for your use. Let us know what you find, and pix of your completed setup, of course! Best of luck, bro! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 Well, pulled the trigger on some Borla tips. They should work fine as their ID is slightly larger than our mufflers' OD. They're clamp-on as well, which should work out really well aesthetically because they can be moved back and forth on the muffler outlet pipe. Hopefully I'll have pics of the install by weekend after next. Oh, yeah, here's a link: Next topic - painting the cans. Anyone know what kind of paint I should use? I'm looking to go black in a flat or satin finish. Wonder if I could get OBP to stick:) Link to comment Share on other sites More sharing options...
rao Posted August 3, 2006 Share Posted August 3, 2006 Uee high-temp paint and they should be fine. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
TSiWRX Posted August 3, 2006 Share Posted August 3, 2006 ^ Would you also recommend some kind of primer, too? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
rao Posted August 3, 2006 Share Posted August 3, 2006 Nope. I have used high temp paint on mufflers to cover up wleds that were rusting and it worked great. I'd follow the instructions on the paint to see if it even needs primer and make sure you get something that can handle the temps. I'd scotchbrite pad the muffler to make sure it is clean, but that's it. It would be easy to re-apply later if needed. Most high-temp pait needs to be "cured" by some heat after applied, so the first few minutes might scare the heck out of you Someone has done this and posted pcitures a long time ago. Then did them in black IIRC and it looked good. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
PGT Posted August 3, 2006 Share Posted August 3, 2006 ThermoTec works nicely. summitracing.com sells it. I had this same idea...did some research into tips....about $120 for what I wanted. Link to comment Share on other sites More sharing options...
rao Posted August 3, 2006 Share Posted August 3, 2006 ^^^ $5 at the local HOme Depot will get the job done. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 ThermoTec works nicely. summitracing.com sells it. I had this same idea...did some research into tips....about $120 for what I wanted. Yeah, the tips ran $104 delivered. Magnaflow tips retail for more than Borla but sell for quite a bit less - go figure. I went with the Borlas because they're clamp-on, which means easier installation plus adjustable tuck. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 ^^^ $5 at the local HOme Depot will get the job done. I think PGT meant $120 total incl. tips, not just the paint:icon_ques Link to comment Share on other sites More sharing options...
CasopoliS Posted August 3, 2006 Share Posted August 3, 2006 I have thought about replacing the tips.... but I love the shape of our tips. Don't want to lose that. I am going to eventually take my tips off, paint the cans flat black... then put the tips back on. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 I have thought about replacing the tips.... but I love the shape of our tips. Don't want to lose that. I am going to eventually take my tips off, paint the cans flat black... then put the tips back on. The Borlas I bought are the same shape as stock but slightly larger. Their big advantage, besides the bling factor, is that they're a clamp-on design. This means you can adjust the tuck quite a bit. Set them all the way out for Hot Import Nights, all the way in the last week of the month when the cops are trying to make their ticket quota and in the Goldilocks position the rest of the time:icon_mrgr Link to comment Share on other sites More sharing options...
PGT Posted August 3, 2006 Share Posted August 3, 2006 I think PGT meant $120 total incl. tips, not just the paint:icon_ques yeah...if you re-read my post, clearly Rob is smoking something today. puff-puff-give!! Link to comment Share on other sites More sharing options...
TSiWRX Posted August 3, 2006 Share Posted August 3, 2006 Cool info. on the paint, rao and PGT. Thanks! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
PGT Posted August 3, 2006 Share Posted August 3, 2006 Someone has done this and posted pcitures a long time ago. Then did them in black IIRC and it looked good. John M did it. moojohn.com for pics? Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 Cool info. on the paint, rao and PGT. Thanks! +1. Talked to Thermotec and they recommended carb or brake cleaner to prep the mufflers. Also, NAPA can typically get their Hi-Heat Coating (good to 2000 deg. F) in a day or 2. They recommended 1 can/muffler but that seems like overkill, especially since it's $12/can. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 3, 2006 Author Share Posted August 3, 2006 John M did it. moojohn.com for pics? Site appears to be under construction. Link to comment Share on other sites More sharing options...
rao Posted August 3, 2006 Share Posted August 3, 2006 The ThermoTec paint is proably great, but you don't need anything nearly that high temp. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
PGT Posted August 3, 2006 Share Posted August 3, 2006 It's like $7 or $8, so hardly overkill though. Good for 1200F. I've used hi-temp BBQ paint before...it flakes off. Not a big deal as it's cheaper and easy to respray. Link to comment Share on other sites More sharing options...
PGT Posted August 3, 2006 Share Posted August 3, 2006 Site appears to be under construction. John's 2005 Subaru Legacy GT http://www.moojohn.com/subaru/mufflers1.jpg Link to comment Share on other sites More sharing options...
TSiWRX Posted August 3, 2006 Share Posted August 3, 2006 +1. Talked to Thermotec and they recommended carb or brake cleaner to prep the mufflers. Also, NAPA can typically get their Hi-Heat Coating (good to 2000 deg. F) in a day or 2. They recommended 1 can/muffler but that seems like overkill, especially since it's $12/can. ^ Good to know! Thanks, bruddah! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
bluesuby Posted August 3, 2006 Share Posted August 3, 2006 A few weeks ago there was a discussion of Borla catback systems which fit the Legacy sedan, but the tips don't look good on the wagon because they should be longer. So if Borla makes tips, why don't they offer a set-up that is slightly longer for the wagon? Too much trouble for them? Link to comment Share on other sites More sharing options...
