The Don Posted July 27, 2006 Share Posted July 27, 2006 i just got my AP in today an i am trying to install it on the PC My problem is the PC interface cable doesnt fit anywhere on the PC.. what do i do? Link to comment Share on other sites More sharing options...
TDC Joe Posted July 27, 2006 Share Posted July 27, 2006 How old is your computer????? I haven't heard of anyone that doesn't have that port on a PC? PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 funny thing is its new...anyway im on another comp now.. an cant figure out how to get the TDC map onto the AP or how to install the AP...I dont see where it says APMM...setup Link to comment Share on other sites More sharing options...
G.T.Subie Posted July 27, 2006 Share Posted July 27, 2006 It broken, give it to me. Denial is your best friend Link to comment Share on other sites More sharing options...
TDC Joe Posted July 27, 2006 Share Posted July 27, 2006 Are you running the Cobb AP software.... PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
-TT- Posted July 27, 2006 Share Posted July 27, 2006 i think it's time to befriend Manuel Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 i did nothing so far cept download the TDC map...i dont see the AP setup window Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 im reading the manual an it says on the AP highlight sync to PC i dont see that tho Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 ok let me start over...im at the part where i cant get the TDC map onto the AP. the AP map mang. screen is up at this time i see where it says TDC map stage 1...there is nothing under the AP base maps/realtime maps Link to comment Share on other sites More sharing options...
TDC Joe Posted July 27, 2006 Share Posted July 27, 2006 You need to use the software to find the map on your hard drive. Then synch the ap to the manager software. Once that is done you can just use the little arrows to move the TDC map to the AP PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
-TT- Posted July 27, 2006 Share Posted July 27, 2006 ^^it sounds like he's found the map, just not syncd up the AP yet do you have the AP plugged into power and on? in the ACTUAL ACCESSPORT MENU (the one on the screen on the accessport itself) there is an option (it is the last option on the list meaning you might have to scroll down) it says sync to PC Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 ya i cant sync it to the comp for some reason, ive tryed 3 diff comps in the house Link to comment Share on other sites More sharing options...
-TT- Posted July 27, 2006 Share Posted July 27, 2006 so when you select "sync to PC" on the AP nothing happens? Link to comment Share on other sites More sharing options...
TDC Joe Posted July 27, 2006 Share Posted July 27, 2006 You have to choose synch to PC on the AP and then the same on the software in the menu. They then findeach other PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
Sk8erOrd Posted July 27, 2006 Share Posted July 27, 2006 Unless Cobb has changed it recently, the AP uses a 9 pin serial cable. A LOT of new computers don't have them. It is a legacy (no pun intended) port. There are adapters that will convert a serial to a usb, though. 2015 Mustang Ecoboost Premium w/ PP (6MT) 2006 LGT Ltd 5MT OBP Cobb Short Throw Shifter | GS Catless Up Pipe Gone Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 i dont see that at all on the AP.. i see please choose a new map to flash... press ok..i than hit ok and i see a few maps.. ie stage 1,2, stock.. than #6 is EMPTY.. there is no sync to PC Link to comment Share on other sites More sharing options...
chenc544 Posted July 27, 2006 Share Posted July 27, 2006 By default the Main screen doesn't come up until you marry the AP to the car first. To bypass that hold down the up and down button and then plug in the AC plug to power up. Then the screen should say something like waiting for PC. Link to comment Share on other sites More sharing options...
The Don Posted July 27, 2006 Author Share Posted July 27, 2006 i figureed i out i needed to hold the up and down buttens to get that sync to work thanks for every1s help Link to comment Share on other sites More sharing options...
iuksob03 Posted July 27, 2006 Share Posted July 27, 2006 is that the same part where it says "this may rednnder the accessport unusable?" I'm having connection problems myself Link to comment Share on other sites More sharing options...
RockyMtnGT Posted July 27, 2006 Share Posted July 27, 2006 When you first connect the power cord to the AP, push and hold the UP arrow and the DOWN arrow to force it to sync with the PC. I had the same trouble as you until i did this. If this doesn't work...go here>>> ActiveKB Knowledgebase The AccessPORT has not yet been married to vehicle. To force it into a Sync to PC mode, you must hold the UP and DOWN arrow at the same time while powering the unit on. After a few seconds the "Sync to PC" screen will appear. Link to comment Share on other sites More sharing options...
