rao Posted September 19, 2004 Share Posted September 19, 2004 I didn't like the idea of running a power wire across the engine bay and then pushing it through the main harness grommet or moving the grommet aside and just shoving it in. While poking around under the hood I noticed the hood release cable and how it went into the wheel well. I had run a power wire like this in a prior car and it worked out great. It turns out that there is a spare grommet next to the main power bundle which puts it in a great place. Unfortunately I only had some 4 gauge power wire laying aournd (which is way more than I need or want) so I didn't run the wire yet. You have to push the grommet out from inside of the car. Here are some pics: 1st is the spare grommet net to the power bundle going to the fuse box Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rao Posted September 19, 2004 Author Share Posted September 19, 2004 Pic 2 of 3 This is taken a little further back and you can see the wheel liner pulled back. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rao Posted September 19, 2004 Author Share Posted September 19, 2004 Pic 3 of 3 showing the routing of the hood release cable near the battery and entering the wheel well. You could run the wire behind the battery and then follow the hood release cable to the grommet. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Deer Killer Posted September 19, 2004 Share Posted September 19, 2004 How about a general location pic? Link to comment Share on other sites More sharing options...
rao Posted September 19, 2004 Author Share Posted September 19, 2004 The grommet is about 5 inches back from the left front wheel well. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rao Posted September 19, 2004 Author Share Posted September 19, 2004 Here is a better shot of the hood release cable as it goes into the wheel well Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Colonel Angus Posted September 20, 2004 Share Posted September 20, 2004 Here is a better shot of the hood release cable as it goes into the wheel well sweet jesus, nice find. more pics please, as i'm looking to install an amp and sub, myself...which from looking at other posts dealing with amp installs and such, looks to be a bitch...stupid sexy proprietary head unit/hvac :x Link to comment Share on other sites More sharing options...
Th3Franz Posted September 20, 2004 Share Posted September 20, 2004 So you used 4 gauge wire... what about 1/0 gauge? Would that fit do you think? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
rao Posted September 20, 2004 Author Share Posted September 20, 2004 No I only had 4 gauge laying aorund and I don't need anything nearly that big. The grommet will handle welding cable if you wanted to run it When I install the cable I will try to remember to take pics. The cable will come in behind the fuse box and then you just need to go across to the center console and to the trunk. Should be easy. Colonel, if you live close enough I would be happy to help you with the install. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
CombatCQB Posted September 27, 2004 Share Posted September 27, 2004 Thanks Rao, I installed my 8 AWG power cable through that grommet today. Ran the wire down the side sills and into the trunk. That location is perfect for running power cables, I only had to remove the bottom and side covers of the dash to gain access to it. I'll post what pictures I have soon Link to comment Share on other sites More sharing options...
CombatCQB Posted September 27, 2004 Share Posted September 27, 2004 Here is the grommet. The cockpit side of the grommet is much bigger than the wheel well side, so I had to pull it out from inside the car. I used a knife to cut a X into the grommet and then put it back before pushing the wire through. Thinking back, it would be easier to push wire through if the grommet was installed backwards with the larger side towards the wheel well. In my case, the grommet fell out a few times when I push the wire in from the wheel well. Link to comment Share on other sites More sharing options...
CombatCQB Posted September 27, 2004 Share Posted September 27, 2004 Access to the grommet is done by removing the under dash panel just above the pedels and the end cover of the dash. Link to comment Share on other sites More sharing options...
CombatCQB Posted September 27, 2004 Share Posted September 27, 2004 I ran the wire down the driver side fo the car and it turned out to be a good choice since a large wire bundle already go through there and the existing wire tie downs had plenty of space to add the 8 AWG wire to it. Link to comment Share on other sites More sharing options...
Cascade-LGT Posted October 7, 2004 Share Posted October 7, 2004 I just installed an amp power cable using this routing. However, the unused grommet is occupied in the wagon. I believe it contains the rear window washer hose. I just used the main grommet and will seal it up with silicone. Still a very good routing option.... Link to comment Share on other sites More sharing options...
Colonel Angus Posted October 9, 2004 Share Posted October 9, 2004 I ran the wire down the driver side fo the car and it turned out to be a good choice since a large wire bundle already go through there and the existing wire tie downs had plenty of space to add the 8 AWG wire to it. how did you pop the molding up like you did in the pics? :?: Link to comment Share on other sites More sharing options...
CombatCQB Posted October 9, 2004 Share Posted October 9, 2004 I ran the wire down the driver side fo the car and it turned out to be a good choice since a large wire bundle already go through there and the existing wire tie downs had plenty of space to add the 8 AWG wire to it. how did you pop the molding up like you did in the pics? :?:Start with the plastic scuff plate which you can pull off by hand. Then pull the weather strip to gain access to the edge of the carpet. The wire tiedowns has clips that hold the carpet molding down as well, you'll need a screw driver to unclip the carpet molding and lift it up. Link to comment Share on other sites More sharing options...
welby Posted March 5, 2008 Share Posted March 5, 2008 Sorry for bringing it back from the dead, but I'm glad I stumbled upon this thread. Thanks Link to comment Share on other sites More sharing options...
Mr. Ed Posted March 5, 2008 Share Posted March 5, 2008 I know right... I wish I would have found this about 3 weeks ago...... Link to comment Share on other sites More sharing options...
Speedracerx Posted March 6, 2008 Share Posted March 6, 2008 +1 An oldie but a goodie...thanks for bringing this back. I going to use it to route my water meth wires/tubing. Link to comment Share on other sites More sharing options...
whobaru Posted March 6, 2008 Share Posted March 6, 2008 I made my own hole after some careful calculations. That's 4 gauge wire. http://i180.photobucket.com/albums/x312/kagenmateer/IMG_2929-1.jpg Link to comment Share on other sites More sharing options...
welby Posted March 6, 2008 Share Posted March 6, 2008 +1 An oldie but a goodie...thanks for bringing this back. I going to use it to route my water meth wires/tubing. Don't mean to take this thread on a tangent, but you're gonna love the meth. I have it on my Buick and I gained 8 lbs of boost and 10 mph in the quarter. I went from 13.6@100.53 to 13.0@110. My tires suck, so my 60's are only 2.2's, I'm left spinning while slower cars beat me . I haven't begun to scratch the surface of what the meth can do. I'm aiming for 11'7s then calling it good As far as the grommet, I have a bombproof older Kenwood amp that I'm gonna throw in the car and probably pick up a decent 10" sub to build around. I have an even more bombproof 15" Punch sub from 1993 (It won't die!) right now, but I don't want something that huge in the car. Those days are officially over for me. I concede to parenthood and responsibility... but not totally, lol Link to comment Share on other sites More sharing options...
whobaru Posted March 6, 2008 Share Posted March 6, 2008 15s ftl Link to comment Share on other sites More sharing options...
welby Posted March 6, 2008 Share Posted March 6, 2008 15s ftl Not in 1993 . I've tried to kill it, believe me. I just carried the logic of "why spend more money on something else when this still works" for alot of years Link to comment Share on other sites More sharing options...
whobaru Posted March 6, 2008 Share Posted March 6, 2008 True dat. Link to comment Share on other sites More sharing options...
Keyser Soze Posted April 10, 2008 Share Posted April 10, 2008 This thread saved my life. Well, it actually saved my firewall and whatever else I would have drilled into. I came here before I grabbed the drill. It took awhile to find this location but I installed 4 gauge wire without drilling anything. Very cool. PITA but cool. Link to comment Share on other sites More sharing options...
