mudcruiserman Posted July 27, 2006 Share Posted July 27, 2006 Will WRX 02-06 4-Pot brakes and rotors bolt up to my 05 legacy which has just a natural 2.5i motor AND CAME FACTORY WITH 16 INCH WHEELS? I am buying 17 inch wrx wheels from an 06 Link to comment Share on other sites More sharing options...
team23jordan Posted July 27, 2006 Share Posted July 27, 2006 it should fit BUT you have to get different wheels Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
trohler Posted July 27, 2006 Share Posted July 27, 2006 should not need different wheels if your getting 06 WRX wheels they should be 17x7 and clear the 4pots, since the 4pots come on the TR WRX with 17s Tolly 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
mudcruiserman Posted July 28, 2006 Author Share Posted July 28, 2006 Will WRX 02-06 4-Pot brakes and rotors bolt up to my 05 legacy which has just a natural 2.5i motor AND CAME FACTORY WITH 16 INCH WHEELS? I am buying 17 inch wrx wheels from an 06 At above post will these bolt right on? what about lines? I know the rotors are bigger how about do I need new/different caliper mounting brackets? Link to comment Share on other sites More sharing options...
trohler Posted July 28, 2006 Share Posted July 28, 2006 you should not need anything else, our NA cars have the same brakes as the WRX's w/o the 4pots. So your lines should work and the 4pot calipers are designed for the 10.5in front rotors. When you do this swap please post info and pic's. Tolly 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
mudcruiserman Posted July 31, 2006 Author Share Posted July 31, 2006 trohler, thanks. If I understand; I won't need new rotors? Link to comment Share on other sites More sharing options...
trohler Posted July 31, 2006 Share Posted July 31, 2006 Check out this link Subaru Research: Outback, Legacy, Forester, Impreza, B9 Tribeca, WRX, STi, spec.B... all models, years, 2007, 2006, 2005.. they have spec's on everything including rotor size and according to that site the 06 WRX's have the same size fronts as the NA Legacys. Tolly Again keep me posted to your progress 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
mudcruiserman Posted August 1, 2006 Author Share Posted August 1, 2006 Subaru Research: Outback, Legacy, Forester, Impreza, B9 Tribeca, WRX, STi, spec.B... all models, years, 2007, 2006, 2005 The above site indicates the 05 and 06 are differrent 10.5 vs 11.5 inch rotors for the NA 2.5i Legacy. It seems the 4-pots probably will bolt on an 06 due to same rotor size. mounts and rotors are probably diff for the 05 any help Link to comment Share on other sites More sharing options...
trohler Posted August 1, 2006 Share Posted August 1, 2006 If you get the 4 pots either just buy stock 11.5 WRX rotors or even better slotted aftermarket ones. Tolly 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted February 26, 2008 Share Posted February 26, 2008 I just ordered the the 4 pot kit ,from king of parts. I hope i don't have to send back my r1 concepts prem rotors(i had ordered for my 2006 2.5i leggy.) Link to comment Share on other sites More sharing options...
