mach_six Posted July 26, 2006 Share Posted July 26, 2006 I just got to work and alarmed my car and heard the car horn go off not the usual beep beep. I haven't driven the car in a while now and just wondering how the hell it got changed? Link to comment Share on other sites More sharing options...
c-lo Posted July 26, 2006 Share Posted July 26, 2006 how many honks? shut all your doors completely? either that or it's telling you it's good to be driven again:lol: 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
whitetiger Posted July 26, 2006 Share Posted July 26, 2006 If you push lock 3 times the horn will honk Link to comment Share on other sites More sharing options...
mach_six Posted July 26, 2006 Author Share Posted July 26, 2006 On the first push, it honk. then I did it subsequently just to make sure I wasn't hearing someone else car or hearing things. I'll check it out but everything was closed cause I just washed the car and i would have notice a door gap... Link to comment Share on other sites More sharing options...
TSiWRX Posted July 26, 2006 Share Posted July 26, 2006 If you push lock 3 times the horn will honk +1 And your manual will also tell you how to change back to the beeps, or disable audible response totally. My wife's always unintentionally changing the way her WRX responds to the remote lock/unlock fob as her double-click speed is not quite in-mesh with the response speed of the fob clicker. Pain in the butt! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Silver05LegGTL Posted July 26, 2006 Share Posted July 26, 2006 Check your trunk... my wife has a bad habit of hitting the trunk release button on the key fob, and then I go to drive it and notice exactly what you are describing. Your trunk is probably not shut all the way. Hope that helps. Link to comment Share on other sites More sharing options...
mach_six Posted July 26, 2006 Author Share Posted July 26, 2006 +1 And your manual will also tell you how to change back to the beeps, or disable audible response totally. My wife's always unintentionally changing the way her WRX responds to the remote lock/unlock fob as her double-click speed is not quite in-mesh with the response speed of the fob clicker. Pain in the butt! Thanks for pointing itl, now what page? I mention I was at work ie don't have hte manual with me. Maybe I need to drive the car more often, sits in the driveway more than 3 weeks maybe the battery is draining and somehow the settings got changed. The keys are left in the same spot untouched. Link to comment Share on other sites More sharing options...
Hanger Posted July 26, 2006 Share Posted July 26, 2006 read the back of the remote ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
mach_six Posted July 26, 2006 Author Share Posted July 26, 2006 What I should say is that when I lock it once it doesn't even beep, it's silent. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 27, 2006 Share Posted July 27, 2006 Thanks for pointing itl, now what page? I mention I was at work ie don't have hte manual with me. Maybe I need to drive the car more often, sits in the driveway more than 3 weeks maybe the battery is draining and somehow the settings got changed. The keys are left in the same spot untouched. I'll try to look through her when I get home tonight. That battery-discharge thing is definitely possible, but it's also somewhat concerning.... <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
LIZARD Posted July 27, 2006 Share Posted July 27, 2006 , sits in the driveway more than 3 weeks maybe the battery is draining and somehow the settings got changed. You should be sanctioned for this. You're lucky the GT doesn't put its self in "auto-pilot" mode and leave you in the middle of the night!! Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
