Dean Posted July 23, 2006 Share Posted July 23, 2006 I know this is a noob question and I've searched quite a bit the last few days getting ready to install my cubbypod. The one thing i'm unsure of is how you tap the power and ground wires. Is it just a matter of cutting back the outside plastic on the cubby light wires, attatching boost gauge wires and securing them with electrical tape? Or is there something I need to get at home depot that will allow for a safe connection. Thanks in advance for your help, this is the one question I haven't found an answer to while searching and obviously I don't know much about electrical wiring. Link to comment Share on other sites More sharing options...
bobo69 Posted July 23, 2006 Share Posted July 23, 2006 http://www.imperialinc.com/img/71259.jpgget these they can be found at walmart any auto parts store or a home depot/ lowes 3M Automotive, Marine and Aerospace : 3Mâ„¢ Electrical Connectors, 03874, 18-14 AWG Quick Connect, 6 packs per case Link to comment Share on other sites More sharing options...
Dean Posted July 23, 2006 Author Share Posted July 23, 2006 thanks bobo Link to comment Share on other sites More sharing options...
bobo69 Posted July 23, 2006 Share Posted July 23, 2006 no problem Link to comment Share on other sites More sharing options...
TSiWRX Posted July 24, 2006 Share Posted July 24, 2006 They're called "vampire taps" or "T-taps" ( T's are shaped a little differently, well, like a "T," of course! ) Make sure you've got the proper gauge tap - and also, use a good pair of pliers or crimpers to clamp down on the tap with the wires. Both of these are critical to having a secure, constant-contact tap. You'll also want to think about taping the tap in-place after you're sure that the connection is good and secure. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
derffred Posted September 25, 2006 Share Posted September 25, 2006 there's only 2 wires on the gauge? (assuming it's mechanical)... power and ground correct? or are there more.. Link to comment Share on other sites More sharing options...
zmarko Posted September 26, 2006 Share Posted September 26, 2006 there's only 2 wires on the gauge? (assuming it's mechanical)... power and ground correct? or are there more.. I have 3 on the 'ebay crap special' that I purchased (and will be replacing soon). Power, ground, and a 3rd orange wire (there were no directions regarding the wires with the gauge). In all my car audio installations over the years, the orange has typically been illumination.....although I'm not sure what it does on my gauge. Link to comment Share on other sites More sharing options...
bobo69 Posted September 26, 2006 Share Posted September 26, 2006 illumination would be my guess as well, a dimmer perhaps... Link to comment Share on other sites More sharing options...
AKLGT Posted September 26, 2006 Share Posted September 26, 2006 i soldered my connections.... better than butt connectors. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
rougeben83 Posted September 27, 2006 Share Posted September 27, 2006 I have 3 on the 'ebay crap special' that I purchased (and will be replacing soon). Power, ground, and a 3rd orange wire (there were no directions regarding the wires with the gauge). In all my car audio installations over the years, the orange has typically been illumination.....although I'm not sure what it does on my gauge. +/- and hook up to switch...or whatever power wire that turns on when you have you dash light up. Link to comment Share on other sites More sharing options...
