LittleBlueGT Posted July 6, 2006 Share Posted July 6, 2006 I agree with you on COBB not communicating properly. I have had my front bar on for about a month now and no problems. I like how you used the shaft collar to hold the bar in place properly. I had a Whiteline RSB that was known to slip from side-to-side and possibly rub the brake lines. I used some rubber tubing (about 1 inch) and clamped it on the RSB with a stainless hose clamp. One on each side worked well to stop lateral movement. I might have to do the same with my COBB FSB. I will be checking soon, to see what kind of lateral movement I get. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
franklin Posted July 6, 2006 Share Posted July 6, 2006 Fantastic write up. Before I even looked at your profile I said to myself- this guy has got to be an engineer ! You likely saved some others some grief and better yet came up with an easy fix. Anyone can bitch but not everyone can come up with practical solutions. Thanks Link to comment Share on other sites More sharing options...
robinlsb Posted July 6, 2006 Share Posted July 6, 2006 I love mine but I am waiting to hear about lowering issues. Fine write up. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
jagcars26 Posted July 6, 2006 Share Posted July 6, 2006 Great writeup. I was contemplating the Cobb set, but I think I will go the Cusco route as there seems to be no issues with them so far. Ding ding ding! winnah! The Cusco sways havent had any problems from day one. Link to comment Share on other sites More sharing options...
HansGT Posted July 6, 2006 Share Posted July 6, 2006 nice write up! if you have not already...think about getting new tires. A great summer tire or a UHP all season will be a great improvement over the RE92's and contribute significantly to your handling. Link to comment Share on other sites More sharing options...
HansGT Posted July 6, 2006 Share Posted July 6, 2006 Ding ding ding! winnah! The Cusco sways havent had any problems from day one. +1 Cusco's for 1 months....zero issues. LOVE THEM! Link to comment Share on other sites More sharing options...
obxt Posted July 6, 2006 Share Posted July 6, 2006 It sounds like right now the Cusco's would be a safer option than the Cobb, and I would guess similar performance. My question is, does anyone know if the Cusco's will fit on an Outback? Link to comment Share on other sites More sharing options...
jagcars26 Posted July 6, 2006 Share Posted July 6, 2006 It sounds like right now the Cusco's would be a safer option than the Cobb, and I would guess similar performance. My question is, does anyone know if the Cusco's will fit on an Outback? Good question,,start a thread and ask. Link to comment Share on other sites More sharing options...
vel0mac Posted July 6, 2006 Author Share Posted July 6, 2006 I just received a very nice note from COBB and they admitted that there was some miscommunication on their end. I am positively impressed with their customer service, and to me that is worth a lot. They are clearly better than many other vendors. At this point in time, they are not suggesting/offering their bars to be used with OBXT cars. They also sent me a photo of their front bar as mounted to a Legacy, and the fit is clearly different than the fit on my OBXT. I am confident that they will get any fitment issues with these bars corrected very soon. Be patient, I think it will be worth it. Link to comment Share on other sites More sharing options...
mccorry Posted July 6, 2006 Share Posted July 6, 2006 Awesome job on the write up! Link to comment Share on other sites More sharing options...
HansGT Posted July 6, 2006 Share Posted July 6, 2006 It sounds like right now the Cusco's would be a safer option than the Cobb, and I would guess similar performance. My question is, does anyone know if the Cusco's will fit on an Outback? Asked around for you about Cusco fitting the Outback.....from PatagonianGT: yes. The set I bought (and sold) came from an OBXT owner. You will have to swap the rear bumpstops out for an LGT set though, as the OBXT has long ones. These are external to the suspension and easy to access, so no biggie. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 6, 2006 Share Posted July 6, 2006 It sounds like right now the Cusco's would be a safer option than the Cobb, and I would guess similar performance. My question is, does anyone know if the Cusco's will fit on an Outback? If I were you I would get COBB's bars and use the fancy little fix that is suggested in this thread. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 11, 2006 Share Posted July 11, 2006 Vel0mac, you can ignore my PM, I didn't see this thread. Hopefully COBB will revise the front because I really want to order a set. You said that they looked different on the LGT? Strange if the OEM bars are ths same P/N... Grrr.. can't wait... must wait... Just because they are the same part number does not mean an aftermarket piece will work for both. COBB's bar is different then stock, and works on the LGT, but obviously has some differences that don't allow it to work on the Outback. This thread shows just what you need to make it work though. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
OhBe1 Posted July 12, 2006 Share Posted July 12, 2006 FWIW, using vel0mac's dimensions: Rear, compared to our LOBW's 15mm bar: 16mm solid USDM LGT is 29% stiffer 20mm hollow JDM is 111% stiffer 18mm solid Swift is 107% stiffer 22.4mm hollow Cobb is 263% stiffer Front, compared to our LOBW's 21mm bar: 25.6mm hollow Cobb is 47% stiffer. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
vel0mac Posted July 12, 2006 Author Share Posted July 12, 2006 I have been in contact with Trey Cobb (he emailed me several hours after I posted this thread initially) and from what I can tell he is working on making the bars fit the OB and the Legacy. He found the info that I sent them very helpful and, in addition to some measurements that I will take for him in the next day or so, my understanding is that they plan on using this info to rectify the fit problems. It sure seems like they are planning on making the front bar fit the XT better. I like mine a lot, the car is a lot more fun to drive and the retrofit is not that difficult. And so far after doing the retrofit I have had ZERO problems. No noise, no rubbing, etc... and NO BROKEN LINKS. By the way, in lieu of the machined spacers that I used, one can most likely also use fixturing washers from McMaster-Carr (p/n: 94768A106) Link to comment Share on other sites More sharing options...
vel0mac Posted July 12, 2006 Author Share Posted July 12, 2006 nice write up! if you have not already...think about getting new tires. A great summer tire or a UHP all season will be a great improvement over the RE92's and contribute significantly to your handling. Thanks for the tip, Han'sGT, I appreciate it. I will look into other tires, but for now I have a lot of tread left and it does not make sense for me to pitch them yet. I guess I'm a bit of a cheapskate Link to comment Share on other sites More sharing options...
SBT Posted July 13, 2006 Share Posted July 13, 2006 vel0mac - superb writeup and analysis of alternatives. And you're a machinist too. Nice. Keep up the good work and every OBW owner should be tipping their hat to you for the effort. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
johndas Posted July 13, 2006 Share Posted July 13, 2006 I thank youa s well...I have the full cobb set for my LGT and the requisite rubbing...nice to see I will be helped by your and all the other reports...makes me glad i chose a product that is backed up by the builder! Link to comment Share on other sites More sharing options...
Max Rebo Posted November 27, 2006 Share Posted November 27, 2006 Bringing this thread back from the netherworld... It seems Cobb has done nothing to fix the front bar design issue. Someone else here recently installed both Cobb bars and the front still has the same problem of being too short so that the endlinks are at extreme angles. Come on, Cobb! Don't fill any more orders for your front bar until you fix the design/fitment issue. Please. Link to comment Share on other sites More sharing options...
IceFlyer Posted November 27, 2006 Share Posted November 27, 2006 Rear fits great. Front too short. But well worth the time to fix for the ride improvement. Link to comment Share on other sites More sharing options...
Max Rebo Posted November 27, 2006 Share Posted November 27, 2006 Ah... my mistake. I re-read the postings and it is the front bar. Link to comment Share on other sites More sharing options...
johndas Posted November 27, 2006 Share Posted November 27, 2006 Ahh..I have the Cobb front and rear and have not fitment issues whatsoever... The new Cobb rear bar rocks the party and all is well! No issues all around! J Link to comment Share on other sites More sharing options...
Max Rebo Posted November 27, 2006 Share Posted November 27, 2006 Hm... maybe I missed something? Is the fitment issue only on Outbacks, then? Or has it been fixed? Link to comment Share on other sites More sharing options...
Rollin Wes Posted November 28, 2006 Share Posted November 28, 2006 I installed the cobb sways about a month ago and the rear bar is great, no problems. But the front is a problem. It keeps walking from side to side and like others have said, its too short. I agree that Cobb should work on the front bar. It is putting some crazy wear on my AVO endlinks. Link to comment Share on other sites More sharing options...
IceFlyer Posted November 28, 2006 Share Posted November 28, 2006 Reading this thread from the begining and $20 can fix your problem. Link to comment Share on other sites More sharing options...
