jagcars26 Posted July 5, 2006 Share Posted July 5, 2006 Here ya go,,not my cupa tea,but to each his own,,, Link to comment Share on other sites More sharing options...
whitetiger Posted July 5, 2006 Share Posted July 5, 2006 can get alot more soap in there now Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 5, 2006 Share Posted July 5, 2006 1-800-ohh-noes If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
axis008 Posted July 5, 2006 Share Posted July 5, 2006 If I put a formentioned "big bulge" in my pants, will the ladies finally call me back? -ben Link to comment Share on other sites More sharing options...
wukindada Posted July 5, 2006 Share Posted July 5, 2006 Ahem......it's supposed to be in the front;) Thats why you are not getting that call back:lol: Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted July 5, 2006 Share Posted July 5, 2006 can get alot more soap in there now winnAr!!!  Jesse Link to comment Share on other sites More sharing options...
SQC049 Posted July 6, 2006 Share Posted July 6, 2006 I kind of like it. I am doing the STI swap and I am concerned about under hood temps and getting enough air flow to the intercooler. I may have to pick one up and give it a try. Maybe, I would like to see pics from further away. Someone buy it. Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039Â PM me an offer! Link to comment Share on other sites More sharing options...
CreoSTi Posted July 6, 2006 Share Posted July 6, 2006 I am doing the STI swap and I am concerned about under hood temps and getting enough air flow to the intercooler. I may have to pick one up and give it a try.  Unless you cut a larger hole into your hood, this won't give you any increase in air flow since we have an integrated scoop (unlike the WRX/STi with the big hole+add-on scoop). This would just fit over the stock hood's existing opening. -Mike- Link to comment Share on other sites More sharing options...
SQC049 Posted July 6, 2006 Share Posted July 6, 2006 Unless you cut a larger hole into your hood, this won't give you any increase in air flow since we have an integrated scoop (unlike the WRX/STi with the big hole+add-on scoop). This would just fit over the stock hood's existing opening. -Mike- True, I know we have a smaller hole in our hoods. But, the front part of the scoop comes out, so if this replaces that piece and sticks up further, it should catch more air flow. Am I off base with my thinking here? Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
SnoDork Posted July 6, 2006 Share Posted July 6, 2006 If I put a formentioned "big bulge" in my pants, will the ladies finally call me back? Nope...You gotta Own a LGT First!! ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
TSiWRX Posted July 6, 2006 Share Posted July 6, 2006 Unless you cut a larger hole into your hood, this won't give you any increase in air flow since we have an integrated scoop (unlike the WRX/STi with the big hole+add-on scoop). This would just fit over the stock hood's existing opening. -Mike- Agreed.  I wanna know where brother praedet went!? I want him to model this and figure out if it'll actually do us any good!  Damn aerospace engineers and their long honeymoons! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
andrew.anderson Posted July 6, 2006 Share Posted July 6, 2006 Here ya go,,not my cupa tea,but to each his own,,, Outstanding! Thanks. Link to comment Share on other sites More sharing options...
CreoSTi Posted July 6, 2006 Share Posted July 6, 2006 But, the front part of the scoop comes out, so if this replaces that piece and sticks up further, it should catch more air flow. Am I off base with my thinking here? I am by no means an aerodynamics expert, but I believe that the existing opening will only let a certain amount of air in (same as the stock hood scoop). The extra air that doesn't make it into the scoop will be forced in and over the opening (since there will be a dead space above the hood and below the scoop). However, this is just how I am conceptually seeing it.  I think that you'd be better off retrofitting an intercooler water spray (like on the STi) for additional cooling with the STi TMIC than this scoop. It'd probably cost around the same anyway. -Mike- Link to comment Share on other sites More sharing options...
SQC049 Posted July 6, 2006 Share Posted July 6, 2006 I am by no means an aerodynamics expert, but I believe that the existing opening will only let a certain amount of air in (same as the stock hood scoop). The extra air that doesn't make it into the scoop will be forced in and over the opening (since there will be a dead space above the hood and below the scoop). However, this is just how I am conceptually seeing it.  I think that you'd be better off retrofitting an intercooler water spray (like on the STi) for additional cooling with the STi TMIC than this scoop. It'd probably cost around the same anyway. -Mike- Yeah, good point. I was going to go with a sprayer for the intercooler anyways, but figured that the extra air couldn't hurt. But I see your point, the hole is only so big, so only a certain amount of air can pass through, no matter how big the scoop is. I don't think it looks bad, but if it does not serve a purpose it is a waste of money, Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
mccorry Posted July 7, 2006 Share Posted July 7, 2006 I want to see photos of the entire car with the scoop..... Link to comment Share on other sites More sharing options...
STi Boy Posted July 7, 2006 Share Posted July 7, 2006 i wouldnt mind a bigger scoop...i want one where i can see the bulge while im sitting inside the car like the old 2.5rs..wrx..sti..etc. does the huge scoop from the 05 STi fit on our LGT?? Link to comment Share on other sites More sharing options...
LawGT Posted July 7, 2006 Share Posted July 7, 2006 Jedi, what the hell is your avatar? looks painful... Link to comment Share on other sites More sharing options...
jvento Posted July 7, 2006 Share Posted July 7, 2006 yea I thought so to andrew.anderson Link to comment Share on other sites More sharing options...
highlander Posted July 7, 2006 Share Posted July 7, 2006 totally..that thing is ricerific. I think it would be really sweet. Replace my OEM spoiler with a big T-handle one, get the A-post mounted chrome fire extinguisher, some GT-R badges, some EL lights to trim the dash......  Man I would be fast! :lol: :lol: Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
praedet Posted July 9, 2006 Share Posted July 9, 2006 The big issue of the STi swap is the different shape of the intercooler vs. the LGTs. This scoop does NOTHING to address that, so there would be no improvement...  Actually, trying to force more air through the same size hole without some nifty nozzles to try and increase air velocity would make some large stagnation regions. The stagnation would in actuallity reduce flow to the IC. So, there is a good chance this scoop would reduce flow to the IC unless you increased the size of the holes in the hood...  Ted TSi: I'm back Link to comment Share on other sites More sharing options...
TSiWRX Posted July 10, 2006 Share Posted July 10, 2006 ^ Ted's back! :DÂ Welcome back, bruddah! And again, congrats on all that's good and recent in your life! Â Listen to brother Ted, boys and gals. He *knows* what he's talking about when it comes to aero stuff!!!!! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
mccorry Posted July 17, 2006 Share Posted July 17, 2006 Welcome back to the board, Ted. Hope you had a nice "trip". Link to comment Share on other sites More sharing options...
KayGT Posted July 17, 2006 Share Posted July 17, 2006 IMHO...horrific Link to comment Share on other sites More sharing options...
HansGT Posted July 18, 2006 Share Posted July 18, 2006 not as bad as whats on the rex. i'd like to see a shot of the entire car. Link to comment Share on other sites More sharing options...
Nachowang Posted July 18, 2006 Share Posted July 18, 2006 Sticks out like a pimple on the hood Thumbs down for me Link to comment Share on other sites More sharing options...
