lo_rezz Posted July 3, 2006 Share Posted July 3, 2006 Hello all - First, I just wanted to say thank you to all that contribute on here. I've only owned my '06 Outback Lmtd. for just over a month, but have already learned a ton on here. I've already switched out my front speakers to Infinity Kappas 62.7i(coaxial style, but with a crossover), and am realising that I need to install an amp. I don't have the funds to put in a Cleansweep at this time, but am ready to do an amp install, and would like to put it under the passenger seat. I plan on putting in a 4 channel amp so I can replace the rear speakers as well. I'd be interested to know the following, and haven't found it by searching on here yet - - Do I need to do anything special to remove the passenger seat? - Is there any concern with the airbag in the seat? - What's the best way to run wiring thru the firewall? - Any good ideas for running speaker wire to the amp and back to the speakers? I'd appreciate any input you all could provide. Link to comment Share on other sites More sharing options...
ZinFreak Posted July 3, 2006 Share Posted July 3, 2006 <snippage> - Do I need to do anything special to remove the passenger seat? Nope, there are four very large bolts that hold the seat to the floor pan. Just use a socket wrench to extract them. - Is there any concern with the airbag in the seat? Disconnect the negative lead from the battery if you are concerned about it going off in your face. - What's the best way to run wiring thru the firewall? There are a couple of rubber grommets that can be popped out, then cut a hole in the middle, route the cable through it. Check my website on a boost gauge install for a pic of where one is located (in back of the TMIC). Got Boost? - Any good ideas for running speaker wire to the amp and back to the speakers? I've got nothing for that, someone may have advice. Have fun, Be Well. -Zin 06 LGT LTD GRP 5MT 07 FXT LTD OBP 4EAT Link to comment Share on other sites More sharing options...
