credit Posted July 13, 2006 Author Share Posted July 13, 2006 about to order cusco coilovers cusco swaybars and access port chippy ... also bbs rims and pirellis Link to comment Share on other sites More sharing options...
captainmorgan Posted July 13, 2006 Share Posted July 13, 2006 captainmorgan - Thanks! How high do you think the Ksports will let you go? Thats a good question! the rears can go maybe another two inches, but I think the front can only handle a maximum of maybe another inch. I'd be too paranoid to run anything more than that, simply because the Ksports are mostly aluminum unlike other coilovers that seem to have steel strut mounts. I do have one problem from dropping so low from stock, and running 245mm wide tires, I have rubbing in the front on full lock. This is partly a result of being low, and having cross caster out 1°. Hope to clock my subframe this weekend and get that fixed. Link to comment Share on other sites More sharing options...
OhBe1 Posted July 13, 2006 Share Posted July 13, 2006 I imagine the camber curve is interesting as well! 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
captainmorgan Posted July 13, 2006 Share Posted July 13, 2006 I'll maybe take some measurements and see what I can come up with for a curve. I'm pretty sure that its almost verticle. Link to comment Share on other sites More sharing options...
DAVES XTOUTBK Posted August 9, 2006 Share Posted August 9, 2006 The first thing to do on an OBXT is to beef-up the rear sway bar and install heavy duty endlinks. I bought mine from AVO and I'm really happy. This was by far the biggest bang for the buck in terms of mod. Oh, and get rid of the crappy tires first chance you get. Does AVO have a website? How much did you pay for the bar and endlinks? Dave Link to comment Share on other sites More sharing options...
sduford Posted August 10, 2006 Share Posted August 10, 2006 They sure do, and they are represented here too. AVOturboworld International Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
DAVES XTOUTBK Posted August 10, 2006 Share Posted August 10, 2006 Sly, did you get both the front and rear links or just the rear? Link to comment Share on other sites More sharing options...
eVoMotion Posted August 11, 2006 Share Posted August 11, 2006 Sounds like Cobb is changing their swaybars to fit the OB better http://legacygt.com/forums/showthread.php?p=713396#post713396 CaptainM and I have similar setups. I raised my to 27.5 to reduce the rub. I have a new alignment and am wondering if this made more difference. Swaybars are the next upgrade - will definitely help when fully loaded and hauling . Link to comment Share on other sites More sharing options...
