SWP-LegacyGT Posted June 28, 2006 Share Posted June 28, 2006 Curious since a LOT of people are selling their stock wheels and figured it might not be a bad idea to have one just in case. Link to comment Share on other sites More sharing options...
meier motor sports Posted June 28, 2006 Share Posted June 28, 2006 it will definatly sit higher and quite possibly be to big around. Link to comment Share on other sites More sharing options...
dv8ingvector Posted June 28, 2006 Share Posted June 28, 2006 It fits fine in the wagon; I just had to remove the foam compartment thingy that sits on top of the spare. Link to comment Share on other sites More sharing options...
Johan Posted June 28, 2006 Share Posted June 28, 2006 How about a sedan? Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted June 28, 2006 Share Posted June 28, 2006 How about a sedan? +1 If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
rurouni_x Posted June 28, 2006 Share Posted June 28, 2006 just checked and they do fit but U might have to take the foam thing out for it to close Link to comment Share on other sites More sharing options...
planigan Posted June 28, 2006 Share Posted June 28, 2006 Haven't tried it myself, but when I bought my sedan the salesman mentioned that a full-size spare would fit fine if you lose the foam tray. Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted June 28, 2006 Share Posted June 28, 2006 just checked and they do fit but U might have to take the foam thing out for it to close I wonder if it will keep the trunk deck from sagging? If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
Johan Posted June 28, 2006 Share Posted June 28, 2006 So it will not be noticable from just looking in the trunk? Has anyone else tried this? Link to comment Share on other sites More sharing options...
TRS Posted June 28, 2006 Share Posted June 28, 2006 I just put a 225/40R18 full size spare in my trunk and it fit in the well with no problem. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted June 28, 2006 Author Share Posted June 28, 2006 Good to hear guys thanks for the feedback. Link to comment Share on other sites More sharing options...
robinlsb Posted June 28, 2006 Share Posted June 28, 2006 It fits fine in the wagon; I just had to remove the foam compartment thingy that sits on top of the spare. +1 "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Adamaxus Posted June 28, 2006 Share Posted June 28, 2006 your avatar is the best! Link to comment Share on other sites More sharing options...
Lagacy GT Posted June 28, 2006 Share Posted June 28, 2006 HOLY SHIT. Now to find someone selling a stock wheel. And, does the AWD fck with this at all? Don't you have to have tires running the same way or whatever? Link to comment Share on other sites More sharing options...
DuraMax Posted June 28, 2006 Share Posted June 28, 2006 HOLY SHIT. Now to find someone selling a stock wheel. And, does the AWD fck with this at all? Don't you have to have tires running the same way or whatever? Yes you do - its important that all the tires are oriented vertically along parrallel planes and not horizontally or a mix of the 2. Link to comment Share on other sites More sharing options...
Sk8erOrd Posted June 28, 2006 Share Posted June 28, 2006 The important thing with AWD is the outside diameter of the TIRE. They have to be within 1/4" of each other to prevent wear to the rest of the drivetrain. When you have to use the donut spare, Subaru says to pull the AWD fuse to force 2 wheel drive use. You will probably see less problems with a full size spare than the donut, especially if there is near equal treadwear. 2015 Mustang Ecoboost Premium w/ PP (6MT) 2006 LGT Ltd 5MT OBP Cobb Short Throw Shifter | GS Catless Up Pipe Gone Link to comment Share on other sites More sharing options...
Lagacy GT Posted June 29, 2006 Share Posted June 29, 2006 sweet, that's what I was asking, not that fcking smartass answer, you fcking moron. <--- that means you're not supposed to be offended you fcking prick. Link to comment Share on other sites More sharing options...
RobE Posted June 29, 2006 Share Posted June 29, 2006 I have a stock tire as my spare. And yes you do have to lose the foam tray and it will cause the cover to sag. My solution was to fold a towel and put that in there. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
f1anatic Posted June 29, 2006 Share Posted June 29, 2006 It fits just fine. But ditch the polyurethane tray. Link to comment Share on other sites More sharing options...
Hanger Posted June 29, 2006 Share Posted June 29, 2006 I just put a 225/40R18 full size spare in my trunk and it fit in the well with no problem. so it does fits? time to find me a spare wheel and tires ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
elpete77 Posted June 29, 2006 Share Posted June 29, 2006 It does fit, everything fits under the tire with the rim facing up. But the full size tires are mostly directional, so you have to be a bit careful with that. Link to comment Share on other sites More sharing options...
hifiandmtb Posted June 29, 2006 Share Posted June 29, 2006 A picture tells a thousand words:Â http://photos.all.id.au/ALBUMS/SJ_Subwoofer-Installation/IMG_6427.sized.jpg Link to comment Share on other sites More sharing options...
loak Posted June 29, 2006 Share Posted June 29, 2006 The important thing with AWD is the outside diameter of the TIRE. They have to be within 1/4" of each other to prevent wear to the rest of the drivetrain. When you have to use the donut spare, Subaru says to pull the AWD fuse to force 2 wheel drive use. You will probably see less problems with a full size spare than the donut, especially if there is near equal treadwear. the fuse doesn't apply to the manual variety of the car, right? Link to comment Share on other sites More sharing options...
Longitude Posted June 29, 2006 Share Posted June 29, 2006 My sedan LGT has full sized spare 225/45/17 + 17x7.5 BBS STI stock wheel, fits perfectly into well. Like others said, need to remove the foam tray though. Link to comment Share on other sites More sharing options...
Joon525 Posted June 29, 2006 Share Posted June 29, 2006 Has anyone thought about trimming the foam tray so that you can still use it? Maybe there's something about the way it's shaped that makes going this route a bad idea but I'm not at my car right now to see for myself. Link to comment Share on other sites More sharing options...
