Alex25 Posted June 26, 2006 Share Posted June 26, 2006 I am going to install Brembo (front and rear) on my JDM Legacy GT B4 2.0T spec.B. Should I also change my stock brake master cylinder to brake master cylinder from WRX STI (GDB)? Link to comment Share on other sites More sharing options...
Opie Posted June 26, 2006 Share Posted June 26, 2006 You can if you'd like (in the U.S. the STi has a slightly larger bore) but the Brembo's will work great with the stocker too. Link to comment Share on other sites More sharing options...
zildjiank Posted December 24, 2006 Share Posted December 24, 2006 Sorry for bringin this back from the dead, but I was wondering whether an STI brake master cylinder would fit on a LGT? And if it did, would it improve braking performance if I'm still stock brakes? Eventually I'm looking at getting a BBK, but for now I'm keeping her stock... Anyone have any experience with the master cylinders? Or know anyone who's done this mod? Link to comment Share on other sites More sharing options...
KNS Brakes Posted December 28, 2006 Share Posted December 28, 2006 The STi MC has a larger bore so it can move more fluid which the Brembo's require. If you install a larger bore MC your travel will be less but your effort will be higher. I wouldn't suggest screwing with that. Link to comment Share on other sites More sharing options...
