MDW25gt Posted June 24, 2006 Share Posted June 24, 2006 I have periodic shudder under braking. I dont think it is warped rotor. I removed both front calipers and freed up the 2 pins that the piston housing floats on. On one side one of the pins was frozen. I tried to "C" clamp it to free it with no luck. Any suggestion how to free it? If not, Suggestion on where to pick up a new caliper? Do you think I should replace both? Thinking I will pop for SS lines at the same time. Thanks, Mike Link to comment Share on other sites More sharing options...
dplacen Posted June 24, 2006 Share Posted June 24, 2006 I have ran into the same problem. I usually heat the caliper bracket and by using power lube and a pair of pliyers I get it free. Your front rotors probably have to be resurfaced very commom on subies. I need to resurface the ones on my car too. I have not have the time yet. Good luck! Link to comment Share on other sites More sharing options...
