MiniStiGuy Posted July 3, 2006 Share Posted July 3, 2006 the only weenie I touch is my own when the g/f doesn't want to cooperate OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
SpeedNeeder Posted August 9, 2006 Share Posted August 9, 2006 So let me get this right: The 06 WRX UP is catless and interchangeable with '05/'06 LGT's? What is the difference between the STI and the WRX UP? I think both pipes have a heat shield, which is why I would prefer one to a 3rd party UP. Radiant heat is not cool! I'm also pro cast and pro flex. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
HansGT Posted August 9, 2006 Share Posted August 9, 2006 So let me get this right: The 06 WRX UP is catless and interchangeable with '05/'06 LGT's? What is the difference between the STI and the WRX UP? I think both pipes have a heat shield, which is why I would prefer one to a 3rd party UP. Radiant heat is not cool! I'm also pro cast and pro flex. Yes. Dunno. Maybe none Why? Heat sheilds, wrap and coating are all good things. Without it your adding to underhood temps. Plus if you keep more heat in the exhaust, gases move faster = quicker spool up. Link to comment Share on other sites More sharing options...
svx6 Posted August 9, 2006 Share Posted August 9, 2006 so no matter what...I need the resistor fix. If I replace the pipe with a bungless one. If I replace the pipe with a gutted stock one. Either way, I am going to get a check engine light because the sensor is either not in use, or not at the correct operating temperature. Correct? Link to comment Share on other sites More sharing options...
j255c Posted August 9, 2006 Share Posted August 9, 2006 strange i found a perfect sti up-pipe (used) for 90 and it Bolted in my car now 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
