armypilot Posted June 21, 2006 Share Posted June 21, 2006 Just have to vent. I am pretty ripped about tearing apart the dash to install a wired modulator for my palm, only to find that SOA apparently decided to use a non-standard antenna cable, rendering the modulator useless:mad: To make matters worse, I scratched the side trim piece in the process! I am starting to miss my '98 Outback limited (minus the launchability of the GT) Subaru's USED to be SO easy to work on the audio systems. Link to comment Share on other sites More sharing options...
LGT Dave Posted June 21, 2006 Share Posted June 21, 2006 You just need an antenna adaptor like this: http://www.crutchfield.com/S-vNx5iGvd8ct/cgi-bin/prodview.asp?i=12040SB10. Easy fix. Link to comment Share on other sites More sharing options...
bmorrisj Posted June 21, 2006 Share Posted June 21, 2006 You just need an antenna adaptor like this: http://www.crutchfield.com/S-vNx5iGvd8ct/cgi-bin/prodview.asp?i=12040SB10. Easy fix. if you go with the fm modulator route you need both that above plug and the reverse, aftermarket to stock plug.... but i do recommend the jazzy setup.... Link to comment Share on other sites More sharing options...
brhays Posted June 22, 2006 Share Posted June 22, 2006 +3 happy customers for Jazzy, I actually ripped out the FM modulator to put it in, and it was like Christmas to my ears. Never start modding, kids. It's too late for me, save yourselves! Hooray for 07+ AccessPORT! Link to comment Share on other sites More sharing options...
armypilot Posted June 22, 2006 Author Share Posted June 22, 2006 I know, after I "cooled off" I figured that it was going to be the best route to do. What I wonder is this - I saw that the 07 has an aux in in the center box next to the aux power. Does anyone if this is something we can retro fit out current radios with? I think it is the spec B that I saw the "aux in" in. Those have the 6 disc changers in them as well (crosses fingers) Link to comment Share on other sites More sharing options...
Claw Posted June 22, 2006 Share Posted June 22, 2006 Lol.. I snapped that funky adapter thing and I had do solder the damn thing in place. Link to comment Share on other sites More sharing options...
Spinjockey Posted June 22, 2006 Share Posted June 22, 2006 I know, after I "cooled off" I figured that it was going to be the best route to do. What I wonder is this - I saw that the 07 has an aux in in the center box next to the aux power. Does anyone if this is something we can retro fit out current radios with? I think it is the spec B that I saw the "aux in" in. Those have the 6 disc changers in them as well (crosses fingers) You'd probably be able to retrofit the 07 armrest aux in with a Jazzy aux in 05/06 radio, but not on the stock 05/06 radio (there's no changer or aux in ports, thus the Jazzy solution). The current suspicion is that the 07 radio will be plug and play with the 05/06 radios but it's all just speculation currently. However cost of a new radio is like $500! But at that point you probably wouldn't need the Jazzy solution then, just have to wire the aux in. So it's a wait of at least a few months and $500+ or it's the Jazzy solution for $45 and a wait of a week or so. Link to comment Share on other sites More sharing options...
rpm6500 Posted June 22, 2006 Share Posted June 22, 2006 I'm waiting for the 07 stereos to become available. I want the built in XM as well as the aux plug. Just something to think about... Link to comment Share on other sites More sharing options...
