c-lo Posted June 21, 2006 Share Posted June 21, 2006 did a quick search, found nothing. need to clean my perrin air filter. a buddy of mine has a cleaning kit from his K&N filter system. Can I use this on the perrin? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
SubieRU Posted June 21, 2006 Share Posted June 21, 2006 Look here: http://www.perrinperformance.com/products/legacy/filter_cleaning.htm They sell a cleaning kit. I also have a question though. How often does the Perrin filter have to be cleaned? Link to comment Share on other sites More sharing options...
c-lo Posted June 21, 2006 Author Share Posted June 21, 2006 Look here: http://www.perrinperformance.com/products/legacy/filter_cleaning.htm They sell a cleaning kit. I also have a question though. How often does the Perrin filter have to be cleaned? yeah, know about the kit, just don't want to buy it:lol: especially if someone wants to give me a similiar one free!!!! 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
TSiWRX Posted June 21, 2006 Share Posted June 21, 2006 I think that any type of degreasing cleaner that's rubber/plastic-safe should be fine.... What you're looking for is some kind of de-greaser, the water-spray thereafter, to wash-off the element, is what really blasts off all the junk. I ordered a "Perrin" cleaner set from OptionsAutoSalon (since I ordered other stuff from them at the same time), and what came was a "generic" cleaning kit, "suitable for all foam-element intakes." Honestly, it smelled, felt, and acted just like non-chlorinated brake-cleaner fluid. Anyone know if it's just the same stuff, but packaged in an aerosol bottle that has a nozzle which is made so it doesn't produce enough pressure to "rip through" the foam element? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Boostjunkie Posted June 21, 2006 Share Posted June 21, 2006 did a quick search, found nothing. need to clean my perrin air filter. a buddy of mine has a cleaning kit from his K&N filter system. Can I use this on the perrin? You can clean the Perrin filter with the K&N solvent, but the oil the K&N kit comes with it too thin and not sticky enough for the foam Perrin filter. The Perrin filter is just a Uni filter, so you can search for cleaning kits for Uni filters. Link to comment Share on other sites More sharing options...
HansGT Posted June 21, 2006 Share Posted June 21, 2006 You can clean the Perrin filter with the K&N solvent, but the oil the K&N kit comes with it too thin and not sticky enough for the foam Perrin filter. The Perrin filter is just a Uni filter, so you can search for cleaning kits for Uni filters. +1 Link to comment Share on other sites More sharing options...
