bikegeek Posted June 20, 2006 Share Posted June 20, 2006 So, I'm experiencing alignment issues as described in this thread: http://www.legacygt.com/forums/showthread.php?t=37079 Because of this, my rear 2 tires are fairly worn on the outside edge (passengers' side is pretty bad.) As I've read on a few posts, I assume I need to change all 4 tires, right? They've got 25K+ miles on them, so there'd probably be a significant difference between new and old tires, right? Link to comment Share on other sites More sharing options...
Xenonk Posted June 20, 2006 Share Posted June 20, 2006 check your toe alignment. Might as well change all 4 tires since you already have more than 25k miles on them already. Keefe Link to comment Share on other sites More sharing options...
SBT Posted June 20, 2006 Share Posted June 20, 2006 Whatever you do, don't just replace two tires/1 axle. Jeopardizing your AWD to do that. As Xenonk mentioned, get new tires on it and then get it realigned to spec. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
GTTuner Posted June 22, 2006 Share Posted June 22, 2006 http://legacygt.com/forums/showthread.php?t=37274 Check this out, you should buy four IMO. Link to comment Share on other sites More sharing options...
